Super Fast Posted October 19, 2011 Share Posted October 19, 2011 Under XP SP3, sometimes I see the following occur, even after a defrag on reboot & System Restore & Hibernate files excluded by default. A random file/folder such as something pertaining to AVG or some other program/app will fail to be fully consolidated & be halfway, or even 75% the way to the opposite end of the disk that the other files are located to. Although this is not a lot of files, it is annoying to see a file here, & a file there persisting in a non-contiguous fashion. Perhaps there can be implemented after a defrag, a check for files still scattered over the disk, & then attempt to consolidate those files, & at least move them closer to the others? Files appear to be defragged, just not consolidated. This is very annoying, because if you ever wanted to do a drive resize so you can partition a drive for the purpose of testing something, then a random file here or there may not sound like much, but a single file can prevent a drive from being properly partitioned as you would like, due to the file(s) persisting in a location that needs to be clear for the partition sizing to be accomplished. I have maybe, 3 or 4 random such blocks, & it is very annoying to me. I hope this will be fixed soon, & that true "consolidation" will be possible! Link to comment Share on other sites More sharing options...
