pondpaul Posted June 6, 2011 Share Posted June 6, 2011 The program gives a chance to clear your recycle bin before running. I think it should also give you a choice to run Ccleaner first as well. i am foreever starting Defraggler and finding it defragging the Tempory internet files, because I forgot to clear these first. regards paul Link to comment Share on other sites More sharing options...
Moderators DennisD Posted June 6, 2011 Moderators Share Posted June 6, 2011 Hi paul, and welcome to Piriform. I know the feeling, and it has been asked for on a number of previous occasions. A program called "DVD Shrink", used for ripping/editing video files, has a check box to launch another program called "DVD Decrypter" immediately after it's done it's thing, to burn the completed files to a blank DVD. A partnership which has worked well for years, and I can't see why Defraggler can't have a similar checkbox to run CCleaner before a defrag. If there are reasons, they escape me at the moment. Link to comment Share on other sites More sharing options...
Super Fast Posted June 13, 2011 Share Posted June 13, 2011 Hopefully if they do this, they will include these 2 options: - Ability to run CCleaner in AUTO mode (auto clean & close, then start Defraggler... Who wants to wait for CCleaner to appear, then click Run CCleaner?) - Ability to detect CCleaner (if in same directory as Defraggler... Such as when a user puts them on a flash drive together in the same folder) & run it with the options set in the .ini file. This should also have the AUTO function enabled for portable flash drive cleaning/defraggling as well! Link to comment Share on other sites More sharing options...
