MaryMac Posted October 2, 2010 Share Posted October 2, 2010 I've used CCleaner for ages, and love it. But recently when I use the program it erases my Firefox history, even though I don't have "history" checked. Can you please advise? I'm not sure what has changed with the program, but I will avoid using it if I can't fix this... Thanks so much for any help you can offer! Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 2, 2010 Moderators Share Posted October 2, 2010 do you have mozilla-sessions checked? try unchecking that and seeing if the problem resolves then report back ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
