ekerazha Posted July 12, 2010 Share Posted July 12, 2010 eMule (Search History) [eMule (Search History)] ID=2080 LangSecRef=3022 Detect=HKCU\Software\eMule Default=True FileKey1=%ProgramFiles%\eMule\config|AC_SearchStrings.dat When you install eMule you have 3 choices Currently, CCleaner eMule cleaning only works if you use the 2nd option (which is not the default one, at least on Vista/7). If you keep the default option (the 1st one), you should search for eMule config inside the user folder (example: %LocalAppData%\eMule\config for Windows 7). You should also provide support for the 3rd option ("All Users" folder?). eMule (File Hashes) [eMule (File Hashes)] ID=2081 LangSecRef=3022 Detect=HKCU\Software\eMule Default=False FileKey1=%ProgramFiles%\eMule\config|known.met FileKey2=%ProgramFiles%\eMule\config|known2.met Same thing. Also, on my system I have "known.met", but I don't have "known2.met" while I have a "known2_64.met" file. eMule 0.50a Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 13, 2010 Moderators Share Posted July 13, 2010 Kudos, great find, great post (see ev'ybody i'm not always cruel :-X ) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Guest MrT Posted July 13, 2010 Share Posted July 13, 2010 Thanks, we'll look into this. Link to comment Share on other sites More sharing options...
