ajjakobb Posted March 5, 2010 Share Posted March 5, 2010 Is it possible to create a print to file or just 'print' option so users can have a hard copy of their configurations? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 5, 2010 Moderators Share Posted March 5, 2010 go to options>Advanced put a check in save settings to ini file go to the ccleaner directory (e.g. c:\program files\ccleaner ) open ccleaner.ini with note pad and print ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
