Kanduser Posted May 27, 2009 Share Posted May 27, 2009 Not sure if this has been requested before... I run CClean on a PC that automatically hibernates at the end of the day and comes out of hibernations the next morning, the issue is that CClean only runs when the PC is restarted unless I force it and in this case it may be weeks or months before I have to reboot the machine. Can an option be added to run the application at a specific time, or after a number of days when it hasn't been run? Ta K Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 28, 2009 Moderators Share Posted May 28, 2009 Using the /AUTO parameter via Windows Task Scheduler will do what you want. Link to comment Share on other sites More sharing options...
Kanduser Posted June 11, 2009 Author Share Posted June 11, 2009 Using the /AUTO parameter via Windows Task Scheduler will do what you want. Doh! The solution was staring me in the face! I use the scheduler to change the power settings so that the machine only goes into hibernation at the desired time. Thanks K Link to comment Share on other sites More sharing options...
