AngryPoet Posted March 8, 2009 Share Posted March 8, 2009 hayy evry1 i had a game a while ago, well not that long ago, it's called Medieval Total War, it was the first one, and then i formatted my computer, is there anyway i can get it back using recuva? I had the installation files on the computer as well as the game. THE HARD DRIVE HAS BEEN FORMATTED and if i can't get it back with recuva, does anyone else have any recommendations to any other software which will help? Thanx AngryPoet Link to comment Share on other sites More sharing options...
Moderators Augeas Posted March 8, 2009 Moderators Share Posted March 8, 2009 Did you miss out the bit after 'I formatted my computer' that says 'Then I reinstalled Windows'? You could try a deep scan with the option Scan for Non-Deleted Files checked. I wouldn't think that the odds on success are too high, though. Link to comment Share on other sites More sharing options...
