thomas09 Posted January 28, 2009 Share Posted January 28, 2009 Hello, after downloading and running defraggler 1.06 (portable), the drive map indicating the different blocks is in greyscale only, although the legend shows the correct colors (see screenshot attached). I've tested this on two systems, both running WinXP, one SP3 and one SP2. Any ideas? Defraggler 1.04 still works fine and in color! Regards, Thomas Link to comment Share on other sites More sharing options...
M_Lyons10 Posted January 28, 2009 Share Posted January 28, 2009 You need to either "Analyze" the drive or begin "Defragmenting" the drive for it to see and report the state of the drive and it's blocks / sectors... Hope that helps... Link to comment Share on other sites More sharing options...
thomas09 Posted January 29, 2009 Author Share Posted January 29, 2009 ... that really worked - thanks a lot! I already tried to start an analysis or an defragmentation, but you have to wait until the analysis is complete before the colors are shown. That's different to earlier versions and therefor I didn't expect it to work this way (and have been not patient enough). Thanks again! Thomas Link to comment Share on other sites More sharing options...
kmillerusaf Posted January 29, 2009 Share Posted January 29, 2009 ... that really worked - thanks a lot! I already tried to start an analysis or an defragmentation, but you have to wait until the analysis is complete before the colors are shown. That's different to earlier versions and therefor I didn't expect it to work this way (and have been not patient enough). Thanks again! Thomas Not 100% sure on this... But that may have to do with the interactive drive map that shows the files in them when you click on the blocks-- Probably needs an analysis/defrag first to be able to function properly. Can anyone else back this up? There's always an exception to the rule. I'm that exception. Desktop ----- AMD Athlon 3700+ (2.64Ghz), 2GB DDR 400, ASUS A8N-SLI Premium, 500GB HD, Windows XP Pro SP3, Avira Antivir Personal At work ----- Intel C2D T1700 (1.6Ghz), 2GB DDR2 667, Dell OUY141, 80GB HD, Windows XP Pro SP2, Symantec 10 Laptop ----- Intel C2D P8400 (2.4 Ghz), 4GB DDR3 1066, Mainboard, 160GB HD, Dualboot: Windows 7/openSUSE 11.1, Avira Antivir Personal Link to comment Share on other sites More sharing options...
M_Lyons10 Posted January 29, 2009 Share Posted January 29, 2009 Not 100% sure on this... But that may have to do with the interactive drive map that shows the files in them when you click on the blocks-- Probably needs an analysis/defrag first to be able to function properly. Can anyone else back this up? That's probably the case, though I can't confirm that. In any event, the interactivity of the drive map is well worth the required analysis to see drive state. I really like the new drive map, as it adds a lot of transparency to the sectors / blocks... I'm glad I could help thomas09, I figured that was what you were experiencing, as that is different from previous releases. Link to comment Share on other sites More sharing options...
