xaver71111 Posted January 27, 2009 Share Posted January 27, 2009 To start things off im trying to reover my music and videos off of my ipod. i know this can be done because ive done it before. the thing is ive never had this specific problem. it appears as though the ipod is completely non accessible. when i plug it in it says i have to reformat it blah blah. well thats the reason i downloaded this program. anyway when i go to select the ipod in recuva it starts to scan but then says "The Parameter is Incorrect". any help is greatly appreciated. Link to comment Share on other sites More sharing options...
xaver71111 Posted January 27, 2009 Author Share Posted January 27, 2009 To start things off im trying to reover my music and videos off of my ipod. i know this can be done because ive done it before. the thing is ive never had this specific problem. it appears as though the ipod is completely non accessible. when i plug it in it says i have to reformat it blah blah. well thats the reason i downloaded this program. anyway when i go to select the ipod in recuva it starts to scan but then says "The Parameter is Incorrect". any help is greatly appreciated. edit: i just thought of something. if i was to reformat the ipod, would recuva still be able to find my files? Link to comment Share on other sites More sharing options...
kmillerusaf Posted January 28, 2009 Share Posted January 28, 2009 edit: i just thought of something. if i was to reformat the ipod, would recuva still be able to find my files? Possible but I think it would depend on how many passes you do. A low-level format might allow you to recover them. Something like a DOD or NSA rated format would probably not yield good results for recovery of your files. There's always an exception to the rule. I'm that exception. Desktop ----- AMD Athlon 3700+ (2.64Ghz), 2GB DDR 400, ASUS A8N-SLI Premium, 500GB HD, Windows XP Pro SP3, Avira Antivir Personal At work ----- Intel C2D T1700 (1.6Ghz), 2GB DDR2 667, Dell OUY141, 80GB HD, Windows XP Pro SP2, Symantec 10 Laptop ----- Intel C2D P8400 (2.4 Ghz), 4GB DDR3 1066, Mainboard, 160GB HD, Dualboot: Windows 7/openSUSE 11.1, Avira Antivir Personal Link to comment Share on other sites More sharing options...
xaver71111 Posted January 28, 2009 Author Share Posted January 28, 2009 so if i used the itunes restore on it you think i would be able to recover my music still? idk its kinda just a shot in the dark and it seems like thats what im gonna have to do anyway cause nothing is letting me look into my ipod. Link to comment Share on other sites More sharing options...
