dbogle51 Posted October 25, 2008 Share Posted October 25, 2008 When I run CCleaner on my WinXP sp3 system I get the following message. Error in InetCpl.cpl Missing entry:ClearMyTracksByProcess Any help appreciated. Link to comment Share on other sites More sharing options...
davey Posted October 25, 2008 Share Posted October 25, 2008 (edited) When I run CCleaner on my WinXP sp3 system I get the following message. Error in InetCpl.cpl Missing entry:ClearMyTracksByProcess Any help appreciated. Hello dbogle51, Welcome to the forums. Take the time to get this if you don't already have it. Link to the following website and download Dial-a-Fix program.It is a most beneficial program for many WinXp users. You need to get this and put it into your C:\Windows folder in case you need to get to it . http://wiki.lunarsoft.net/wiki/Dial-a-fix It is always good to have this program on your WinXP PC. I have used it many times to get me out of trouble. At the bottom of the Dial-a-fix window click on the Hammer(tools). You need SFC purge and then SFC scan. You may need your install disk also. The purge is for security reasons. DO NOT DO IT IF YOU DON"T HAVE YOUR INSTALL DISK AVAILABLE. You can do the SFC scan. This will reload your system files with fresh copies. Good luck, davey P.S. You can use Start > Run and enter this command sfc.exe /scannow But you should take the time NOW to get Dial-a-fix if you don't already have it. Edited October 25, 2008 by davey Link to comment Share on other sites More sharing options...
dbogle51 Posted October 26, 2008 Author Share Posted October 26, 2008 Thanks. Hello dbogle51,Welcome to the forums. Take the time to get this if you don't already have it. Link to the following website and download Dial-a-Fix program.It is a most beneficial program for many WinXp users. You need to get this and put it into your C:\Windows folder in case you need to get to it . http://wiki.lunarsoft.net/wiki/Dial-a-fix It is always good to have this program on your WinXP PC. I have used it many times to get me out of trouble. At the bottom of the Dial-a-fix window click on the Hammer(tools). You need SFC purge and then SFC scan. You may need your install disk also. The purge is for security reasons. DO NOT DO IT IF YOU DON"T HAVE YOUR INSTALL DISK AVAILABLE. You can do the SFC scan. This will reload your system files with fresh copies. Good luck, davey P.S. You can use Start > Run and enter this command sfc.exe /scannow But you should take the time NOW to get Dial-a-fix if you don't already have it. Link to comment Share on other sites More sharing options...
