slowday444 Posted April 18, 2008 Share Posted April 18, 2008 I want to add/merge the following into the registry, however, I get confused everytime I try. The directions are: "copy/past into txtile,save as file.reg and import". [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run] "TFTray"=""C:\\Program Files\\ThreatFire\\TFTray.exe"" Is it a Key, String Value, Binary Value, DWORD Value, Multi-String Value or Expandable String Value? What is with the all the quotation marks and do I need them? If I go to [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run], do I just paste "TFTray..."? I'm not afraid to do this, I've backed the registry up, I just want to do it correctly. Thank You! Link to comment Share on other sites More sharing options...
YoKenny Posted April 19, 2008 Share Posted April 19, 2008 Create ThreatFire.reg with Notepad Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run] "TFTray"="C:\\Program Files\\ThreatFire\\TFTray.exe" Insure that you have one blank line at the end and that the file extension is .reg and not .txt then right click on the .reg file and choose Merge. I find it really weird that ThreatFire does not have an option to Start With Windows I'm not going to try it http://www.threatfire.com/download/ Advanced program options V x AntiVirus engine with signature updates V x On-demand scanning of your entire PC for known threats V x Cost Special! $29.95 Free In other words the Pro version is the one that works and the FREE version is a demo. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to comment Share on other sites More sharing options...
