cashtonh Posted February 9, 2008 Share Posted February 9, 2008 When I run my free version of CCleaner it functions fine except that it indicates cleaning my backup hard drive "D". All the files listed as being cleaned start with "D\****". This "D" drive is a clone of the "C" to be used in case of emergency. I recently had a crash in my"C" drive and had to clone "D" back to "C". Everything works perfectly except for this program which thinks it is cleaning the "D" drive. I have uninstalled the program and downloaded the latest version but still the same problem. When checking "properties" for this program it indicates correctly that it is in "C\Program Files". I think that it is cleaniing the "C" drive but it indicates "D". Can any explain this to me?? Link to comment Share on other sites More sharing options...
davey Posted February 9, 2008 Share Posted February 9, 2008 whoops Link to comment Share on other sites More sharing options...
davey Posted February 9, 2008 Share Posted February 9, 2008 (edited) I recently had a crash in my"C" drive and had to clone "D" back to "C". Hi cashtonh, I am no Expert. If you will expound on how you created the original "clone". Then how you "cloned" "D" back to "C". It may provide enough information for a more experienced member to propose an explanation. Best Wishes, davey P.S. I would be interested what the corresponding statement in your CCleaner.ini file says. BackupDir=C:\Documents and Settings\User\My Documents. Other members with OS on their "D" drive(partition) may be interested also. You may have a solution to answer their inquiries. Edited February 9, 2008 by davey Link to comment Share on other sites More sharing options...
Guest_Jim_* Posted February 10, 2008 Share Posted February 10, 2008 You could try uninstalling CCleaner, restarting the computer, and then reinstalling CCleaner. Link to comment Share on other sites More sharing options...
