tinsils Posted December 28, 2007 Share Posted December 28, 2007 All of a sudden, I cannot minimize CCleaner window. Don't know if it was a bug (a while back, seemed to be corrected in new version) and with current version, it's happening again. Thanks Link to comment Share on other sites More sharing options...
davey Posted December 28, 2007 Share Posted December 28, 2007 All of a sudden, I cannot minimize CCleaner window. Don't know if it was a bug (a while back, seemed to be corrected in new version) and with current version, it's happening again.Thanks Hi tinsils, I have a minimum amount of PC experience but I have learned very much on this forum. I do have decades of programming and debugging knowledge. I ran some tests and I think I have found where the problem occurs. It happens when you have a maximized window in CCleaner and you close with the window maximized using the red X icon. This is your fix. Start CCleaner. The window is now Maximized. Click on the minimized icon. The window is gone and CCleaner now shows in task bar at the bottom of your screen. Right click on the CCleaner task at the bottom of the screen. Click on Close. Start CCleaner again. Your CCleaner window shold now be minimized. Try to avoid closing CCleaner with a Maxiized window until bug is fixed. You may need this procedure again until the bug is fixed. Add a link to it in your Favorites in a folder named Temp Fixes. Hope that folder doesn't get too full but it will come in handy. Best Wishes and Happy New Year!!! Help support your local forum. davey Link to comment Share on other sites More sharing options...
tinsils Posted December 29, 2007 Author Share Posted December 29, 2007 Hi tinsils,I have a minimum amount of PC experience but I have learned very much on this forum. I do have decades of programming and debugging knowledge. I ran some tests and I think I have found where the problem occurs. It happens when you have a maximized window in CCleaner and you close with the window maximized using the red X icon. This is your fix. Start CCleaner. The window is now Maximized. Click on the minimized icon. The window is gone and CCleaner now shows in task bar at the bottom of your screen. Right click on the CCleaner task at the bottom of the screen. Click on Close. Start CCleaner again. Your CCleaner window shold now be minimized. Try to avoid closing CCleaner with a Maxiized window until bug is fixed. You may need this procedure again until the bug is fixed. Add a link to it in your Favorites in a folder named Temp Fixes. Hope that folder doesn't get too full but it will come in handy. Best Wishes and Happy New Year!!! Help support your local forum. davey Hey, I'm impressed ! So, it IS a bug NOT just me. Thank You so much...back at ya on the Holdiay Wishes Link to comment Share on other sites More sharing options...
Admin MrG Posted January 2, 2008 Admin Share Posted January 2, 2008 Thanks I'll look into this. Piriform.com - [CCleaner - Defraggler - Recuva - Speccy] Link to comment Share on other sites More sharing options...
