iSteezo Posted May 16, 2010 Share Posted May 16, 2010 Every time i click on CCleaner off my desktop to open it up to clean files it opens up then closes about 3 seconds later what do i do? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 17, 2010 Moderators Share Posted May 17, 2010 1. Right click the CCleaner shortcut and verify it has these default properties in the 'Target' field: "C:\Program Files\CCleaner\CCleaner.exe" if it has this "C:\Program Files\CCleaner\CCleaner.exe" /AUTO it will automatically run, then automatically close. If it doesn't have the default properties you can always edit the desktop shortcut to fix it. 2. Make sure you don't have it set to automatically close by opening: Options->Advanced then make sure there isn't a tick in the box: Close program after cleaning. Link to comment Share on other sites More sharing options...
