jlhns Posted March 11, 2010 Share Posted March 11, 2010 V229.1111 won't analyze or clean Advanced>Custom Files and Folders. The folder I included is C:\Sandbox\*.* I reinstalled V228.1091 and it works fine. My system is XP Home SP2 Link to comment Share on other sites More sharing options...
Moderators DennisD Posted March 11, 2010 Moderators Share Posted March 11, 2010 Hi jlhns, and welcome to Piriform. I think the latest version needs the "Recurse Subfolders" box checked: Hope that helps, and you should really upgrade to SP3, as support for SP2 ends on July 13th this year. http://support.microsoft.com/ph/6794 If you need any advice on that just post back. Link to comment Share on other sites More sharing options...
jlhns Posted March 12, 2010 Author Share Posted March 12, 2010 Hi jlhns, and welcome to Piriform. I think the latest version needs the "Recurse Subfolders" box checked: Hope that helps, and you should really upgrade to SP3, as support for SP2 ends on July 13th this year. http://support.microsoft.com/ph/6794 If you need any advice on that just post back. Thanks Dennis, that worked. As for SP3, I've tried to upgrade twice and both times I got the blue screen of death which necessitated a complete OS and software reinstall. I decided not to try for the third time's a charm. If I have major problems after support ends for SP2, I'll just get rid of this four year old Dell dinosaur laptop and get a new one. Thanks again. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted March 12, 2010 Moderators Share Posted March 12, 2010 If it's any help, there are a few ways to update to SP3, all of which are described in the linked to page. I opted for downloading the ISO file and burning it to disk. This gave me an SP3 backup CD in case I ever had to reinstall Windows, which would have taken me back to SP2. There's also a link to an MS page describing how to prepare your PC for the upgrade, including removing certain MS Updates which make the install fail. http://www.pcworld.com/article/145810/inst...this_first.html Apologies of course if you've already looked into all this. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 13, 2010 Moderators Share Posted March 13, 2010 You can also make a slipstreamed/integrated XP install CD (or DVD if you fancy) with SP3 already built into it, of course that means a reinstall just to have SP3 so it may very well not be worth the hassle. Such a free tool that allows such is nLite which I've used with success. Link to comment Share on other sites More sharing options...
