Flash Storage not cleaned properly
  • Moderators
The only way to kill the list in the first link you provided (other than from that link) is to delete
%appdata%\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys\settings.sol
Of course this will delete ALL of your Flashplayer settings which is fine if you don't have sites you want to save
you can also add
[*Adobe Flash All Site History]
Warning=This will remove all sites from Flash Player's Settings (Trusted sites, Privacy, Storage and Peer Assisted Networking). There is no way to exclude sitea.
LangSecRef=3023
Detect=HKCU\Software\Macromedia\FlashPlayer
Default=False
FileKey1=%appdata%\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys|settings.sol
to your winapp2.ini and it'llclean some of the information
Link to comment
Register a new account
Sign in
Important Information
