Get Application Path from Registry
Disk4mat
  • 2 weeks later...
Is it possible to detect a program/folder path from a registry entry? For example if you install a program to another folder (not using the default) CC wont find it.
Well you do a search of the registry for the exe name that will show its installed location. The uninstall info knows the location else how does it know what to uninstall? ;)
Keith
Windows XP 2002 SP3
IE 7.0
Martin2k
Rorshach112 is the best
Link to comment
Register a new account
Sign in
Important Information
