hwpratt Posted December 7, 2021 Share Posted December 7, 2021 I get this error in a pop up dialog when trying to delete a System Restore Point with CCleaner v5.87.9306 (64-bit) Link to comment Share on other sites More sharing options...
Guest MeganCCleaner Posted December 8, 2021 Share Posted December 8, 2021 Hi @hwpratt Can you please see if you also receive an error when attempting to delete the System Restore point in Windows, using the following steps? Open the "Run" dialog in Windows (On the keyboard, hold the "Windows" ( ) and "R" keys simultaneously) Type: cleanmgr > click OK Click "Clean up system files" Open the "More Options" tab Under the "System Restore and Shadow Copies" section, click "Clean up..." Click "Delete" If this does work, would you be willing to create some new System Restore points in Windows, then check to see if CCleaner continues to generate error 87 when attempting to delete them? Link to comment Share on other sites More sharing options...
