qwerty77 Posted April 17, 2017 Share Posted April 17, 2017 As the title says... CCleaner force closes everytime I run it (the close program setting is not ticked). I think this problem started after the April Patch Tuesday of Microsoft but i'm not entirely sure. The active system monitoring is also affected it also force closes after it runs and or after it detects a browser closing or the limit I've set (5.0gb) on the system wide setting.Using Windows 8.1 Pro x64. I'm also using the latest version of CCleaner (5.28.6005). Any ideas on how I can fix this? Thanks a lot. Link to comment Share on other sites More sharing options...
Moderators mta Posted April 17, 2017 Moderators Share Posted April 17, 2017 perhaps it is set to save your settings to an .INI file and things are screwed up somehow. have you tried uninstalling, rebooting, deleting the CCleaner folder in Program Files (copying your .INI file somewhere if you need/use it) and reinstalling? Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
qwerty77 Posted April 17, 2017 Author Share Posted April 17, 2017 perhaps it is set to save your settings to an .INI file and things are screwed up somehow. have you tried uninstalling, rebooting, deleting the CCleaner folder in Program Files (copying your .INI file somewhere if you need/use it) and reinstalling? Yes I've tried reinstalling and deleting the entire CCleaner folder using a uninstaller software but still the same. Link to comment Share on other sites More sharing options...
qwerty77 Posted April 19, 2017 Author Share Posted April 19, 2017 UPDATE the latest version fixed it for me. Link to comment Share on other sites More sharing options...
