john god Posted March 27, 2006 Share Posted March 27, 2006 Hello, When I go into my e-mail I get [Outlook Express could not be started because MSOE.DLL could not be loaded.] Running Windows 98SE...IE #6.....OE #6 Thanks, John Link to comment Share on other sites More sharing options...
AndyManchesta Posted March 27, 2006 Share Posted March 27, 2006 Hi John god Try these links. Error message "Outlook Express could not be started because Msoe.dll could not be loaded" OLEXP: Error Message: Outlook Express Could Not Be Started Because MSOE.DLL Could Not Be Loaded Outlook is throwing a wobbler over msoe.dll - pcanswers site Andy Link to comment Share on other sites More sharing options...
john god Posted March 28, 2006 Author Share Posted March 28, 2006 Ran windows update. Now it says the same thing, except it has MSOERES.DLL, could not be loaded. John Link to comment Share on other sites More sharing options...
AndyManchesta Posted March 28, 2006 Share Posted March 28, 2006 Hi John , Ive never used Win98 and hardly ever use Outlook so hopefully other members can give you some advise but from reading the support pages it sounds like either some of the .dll file versions are mixed up or there is corrupt/missing information in the Identities registry key. Here's afew more links that explain the problem and many suggest removing Outlook and all its files then reinstalling but Its probably worth waiting incase other members know an easier way to repair things or consider contacting Microsoft by choosing your location then use the Contact link at the bottom of the screen or post the question on one of Microsoft's Outlook newsgroups. Outlook Express could not be started because MSOE.DLL could not be loaded" when you start Outlook Express How to Manually Uninstall and Reinstall Outlook Express on Windows Millennium You receive an error message or are unable to start Outlook Express Inside Outlook Express All The Best Andy Link to comment Share on other sites More sharing options...
john god Posted March 28, 2006 Author Share Posted March 28, 2006 Thanks for all your help. I now have it working properly. Thank You All, John God Link to comment Share on other sites More sharing options...
