Kumar_Shah Posted August 24, 2015 Share Posted August 24, 2015 In Windows 10, with these settings: Case I A. Windows Control Panel>Display>Screen Resolution set at 2560x1600 (native resolution of my monitor) B. NVidia Control Panel>Display>Change Resolution set at 2560x1600 (native resolution of my monitor) C. Windows Settings>System>Display>Change the size of text, apps and other items set at 100% Speccy shows the monitor resolution at 2560x1600. CaseII When I change C. Windows Settings>System>Display>Change the size of text, apps and other items set at 150% Speccy shows the monitor resolution at 1707x1067. In Windows 7, changing size of text etc. did not change the reported resolution. My questions: Is Speccy showing the correct resolution in Case II? Is this a problem with Windows 10. Link to comment Share on other sites More sharing options...
