Hulk701 Posted April 22, 2012 Share Posted April 22, 2012 I have a usb hard drive, Seatgate, 400gb that was divided by a partition. One was called Stuff and the other was called Backups. Neither is showing up on the drive which is why I bought Recuva. Un order to use Recuva I have to be able to point to the drive that is in trouble. I can't do that if I can't see it. It shows up in "Computer Management" as 'unallocated' space. It doesn't show up as a drive letter. How can I recover my files. It is an IDE that can be attached via a USB cable or if need be to a IDE cable. Thanks PS: Below is a picture. It have two sections clearly named and labeled. One should say Backups and have a letter after it and the other should say Stuff and have a letter after it. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted April 22, 2012 Moderators Share Posted April 22, 2012 Hi Hulk701, and welcome to the forum. Have a look at "Minitools Partition Recovery 5.0", which can scan for and restore lost/deleted partitions ... "Minitools Partition Recovery": (Free) It's sister program "Minitools Partition Wizard 7" can also scan for lost partitions ... "Minitools Partition Wizard 7": (Free) Try the first one first, as it's a dedicated partition recovery tool, and the other is Partition Manager application. If you don't have success with those, then you can try "Eassos PartitionGuru Free", which also has a Partition Recovery feature. "Eassos PartitionGuru Free": Odd though it may seem, one of these programs could succeed where another one fails. I've had that happen myself. How to recover partitions using PartitionGuru: All these programs will pick up a USB Hard Drive. Good luck, and let us know how you get on. Link to comment Share on other sites More sharing options...
