BoomBox Posted November 26, 2010 Share Posted November 26, 2010 1. When Speccy is gathering SMART status of HDD then computer hangs and CPU utilization becomes at 100%, HDD LED is on permanently. Trying to run speccy.exe with /debug command line switch does not provide any logs. 2. Update CPU data, Update Video data, Update SMART data. What are these settings do? My system is guaranteed to work stable. Sorry for bad English Software: Windows XP SP3, nForce3 Driver 5.03 Hardware: --------[ CPU ]--------------------------------------------------------------------------------------------------------- CPU Properties: CPU Type AMD Athlon 64, 2200 MHz (11 x 200) 3200+ CPU Alias Newcastle S754 CPU Stepping DH-CG Instruction Set x86, x86-64, MMX, 3DNow!, SSE, SSE2 Original Clock 2200 MHz Min / Max CPU Multiplier 4x / 11x L1 Code Cache 64 KB (Parity) L1 Data Cache 64 KB (ECC) L2 Cache 512 KB (On-Die, ECC, Full-Speed) CPU Physical Info: Package Type 754 Pin uOPGA Package Size 4.00 cm x 4.00 cm Transistors 68.5 million Process Technology 9Mi, 0.13 um, CMOS, Cu, SOI Die Size 144 mm2 Core Voltage 1.500 - 1.550 V I/O Voltage 1.2 V + 2.5 V Maximum Power 89.0 W CPU Utilization: CPU #1 0 % --------[ Motherboard ]------------------------------------------------------------------------------------------------- Motherboard Properties: Motherboard ID 09/07/2006-nForce-6A61CPAFC-00 Motherboard Name Epox EP-8KDA3I Front Side Bus Properties: Bus Type AMD Hammer Real Clock 200 MHz Effective Clock 200 MHz HyperTransport Clock 800 MHz Memory Bus Properties: Bus Type DDR SDRAM Bus Width 64-bit DRAM:FSB Ratio CPU/11 Real Clock 201 MHz (DDR) Effective Clock 402 MHz Bandwidth 3215 MB/s Motherboard Physical Info: CPU Sockets/Slots 1 Socket 754 Expansion Slots 6 PCI, 1 AGP RAM Slots 3 DDR DIMM Integrated Devices Audio, LAN Form Factor ATX Motherboard Size 240 mm x 300 mm Motherboard Chipset nForce3-250 --------[ SPD ]--------------------------------------------------------------------------------------------------------- [ DIMM1: Patriot Memory PSD1G400 ] Memory Module Properties: Module Name Patriot Memory PSD1G400 Serial Number None Module Size 1 GB (2 ranks, 4 banks) Module Type Unbuffered Memory Type DDR SDRAM Memory Speed PC3200 (200 MHz) Module Width 64 bit Module Voltage SSTL 2.5 Error Detection Method None Refresh Rate Reduced (7.8 us), Self-Refresh Memory Timings: @ 200 MHz 3.0-4-4-8 (CL-RCD-RP-RAS) / 12-14-2 (RC-RFC-RRD) @ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) / 10-12-2 (RC-RFC-RRD) Memory Module Features: Early RAS# Precharge Not Supported Auto-Precharge Not Supported Precharge All Not Supported Write1/Read Burst Not Supported Buffered Address/Control Inputs Not Supported Registered Address/Control Inputs Not Supported On-Card PLL (Clock) Not Supported Buffered DQMB Inputs Not Supported Registered DQMB Inputs Not Supported Differential Clock Input Supported Redundant Row Address Not Supported [ DIMM2: Patriot Memory PSD1G400 ] Memory Module Properties: Module Name Patriot Memory PSD1G400 Serial Number None Module Size 1 GB (2 ranks, 4 banks) Module Type Unbuffered Memory Type DDR SDRAM Memory Speed PC3200 (200 MHz) Module Width 64 bit Module Voltage SSTL 2.5 Error Detection Method None Refresh Rate Reduced (7.8 us), Self-Refresh Memory Timings: @ 200 MHz 3.0-4-4-8 (CL-RCD-RP-RAS) / 12-14-2 (RC-RFC-RRD) @ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) / 10-12-2 (RC-RFC-RRD) Memory Module Features: Early RAS# Precharge Not Supported Auto-Precharge Not Supported Precharge All Not Supported Write1/Read Burst Not Supported Buffered Address/Control Inputs Not Supported Registered Address/Control Inputs Not Supported On-Card PLL (Clock) Not Supported Buffered DQMB Inputs Not Supported Registered DQMB Inputs Not Supported Differential Clock Input Supported Redundant Row Address Not Supported --------[ Chipset ]----------------------------------------------------------------------------------------------------- [ North Bridge: AMD Hammer IMC ] North Bridge Properties: North Bridge AMD Hammer IMC Supported Memory Types DDR-200 SDRAM, DDR-266 SDRAM, DDR-333 SDRAM, DDR-400 SDRAM Revision 00 In-Order Queue Depth 8 Memory Timings: CAS Latency (CL) 3T RAS To CAS Delay (tRCD) 4T RAS Precharge (tRP) 4T RAS Active Time (tRAS) 8T Row Cycle Time (tRC) 12T Row Refresh Cycle Time (tRFC) 14T Command Rate (CR) 2T RAS To RAS Delay (tRRD) 2T Write Recovery Time (tWR) 3T Read To Write Delay (tRTW) 4T Write To Read Delay (tWTR) 2T Write CAS Latency (tWCL) 1T Refresh Period (tREF) 200 MHz 7.8 us DQS Skew Control Disabled DRAM Drive Strength Normal DRAM Data Drive Strength 4 (No Reduction) Max Async Latency 7 ns Read Preamble Time 5.5 ns Idle Cycle Limit 16 Dynamic Idle Cycle Counter Enabled Read/Write Queue Bypass 8 Bypass Max 4 32-byte Granularity Enabled Error Correction: ECC Supported, Disabled ChipKill ECC Not Supported RAID Not Supported DRAM Scrub Rate Disabled L1 Data Cache Scrub Rate Disabled L2 Cache Scrub Rate Disabled Memory Slots: DRAM Slot #1 1 GB (PC3200 DDR SDRAM) DRAM Slot #2 1 GB (PC3200 DDR SDRAM) [ South Bridge: nVIDIA nForce3 250Gb/Ultra (CK8S) ] South Bridge Properties: South Bridge nVIDIA nForce3 250Gb/Ultra (CK8S) Revision A2 Package Type 752 Pin BGA Process Technology 0.15 um AGP Controller: AGP Version 3.00 AGP Status Enabled AGP Device ATI Radeon HD 4670 AGP (RV730), ATI RV710/730/740 - High Definition Audio Controller Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Supported, Enabled Side Band Addressing Supported, Enabled Clock Generator: CPU FSB 200.0 MHz HyperTransport 800.0 MHz PCI 33.3 MHz AGP 66.7 MHz MII 25.0 MHz MAC PHY 125.0 MHz SATA PHY 100.0 MHz Audio/Modem Codec 24.6 MHz USB2 Controller 48.0 MHz PIT / ACPI Timer 14.3 MHz --------[ BIOS ]-------------------------------------------------------------------------------------------------------- BIOS Properties: BIOS Type Award BIOS Version 09/07/2006 For nForce3 250 Chipset Award BIOS Type Phoenix - AwardBIOS v6.00PG Award BIOS Message 09/07/2006 For nForce3 250 Chipset System BIOS Date 09/07/06 Video BIOS Date 06/03/09 --------[ PCI / AGP Video ]--------------------------------------------------------------------------------------------- ATI Radeon HD 4670 AGP (RV730) Video Adapter ATI Radeon HD 4670 AGP (RV730) 3D Accelerator --------[ PCI / PnP Audio ]--------------------------------------------------------------------------------------------- ATI Radeon HDMI @ ATI RV710/730/740 - High Definition Audio Controller PCI Creative SB X-Fi Fatality XtremeGamer Sound Card PCI --------[ Physical Drives ]--------------------------------------------------------------------------------------------- [ Drive #1 - WDC WD2500KS-00MJB0 (232 GB) ] #1 (Active) NTFS C: (SYSTEM) 0 MB 33675 MB #2 NTFS D: (DATA) 33675 MB 204797 MB [ Drive #2 - WDC WD800JD-22LSA0 (74 GB) ] #1 (Active) NTFS T: (TEMP) 0 MB 76316 MB [ Drive #3 - KingstonDataTraveler 2.0 (1968 MB) ] #1 (Active) NTFS F: 0 MB 1967 MB --------[ ATA ]--------------------------------------------------------------------------------------------------------- [ WDC WD2500KS-00MJB0 (WD-WCANKJ194658) ] ATA Device Properties: Model ID WDC WD2500KS-00MJB0 Serial Number WD-WCANKJ194658 Revision 02.01C03 Device Type SATA-II Parameters 484521 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector LBA Sectors 488397168 Buffer 16 MB Multiple Sectors 16 ECC Bytes 50 Unformatted Capacity 238475 MB ATA Standard ATA/ATAPI-7 ATA Device Features: 48-bit LBA Supported Advanced Power Management Not Supported Automatic Acoustic Management Supported, Disabled Device Configuration Overlay Supported DMA Setup Auto-Activate Not Supported General Purpose Logging Supported Host Protected Area Supported, Enabled In-Order Data Delivery Not Supported Native Command Queuing Not Supported Phy Event Counters Supported Power Management Supported, Enabled Power-Up In Standby Supported, Disabled Read Look-Ahead Supported, Enabled Release Interrupt Not Supported Security Mode Supported, Disabled SMART Supported, Enabled SMART Error Logging Supported SMART Self-Test Supported Software Settings Preservation Supported, Enabled Streaming Not Supported Tagged Command Queuing Not Supported Write Cache Supported, Enabled SSD Features: Data Set Management Not Supported Deterministic Read After TRIM Not Supported TRIM Command Not Supported [ WDC WD800JD-22LSA0 (WD-WMAM9D811607) ] ATA Device Properties: Model ID WDC WD800JD-22LSA0 Serial Number WD-WMAM9D811607 Revision 06.01D06 Device Type SATA-II Parameters 155061 cylinders, 16 heads, 63 sectors per track, 512 bytes per sector LBA Sectors 156301488 Buffer 8 MB Multiple Sectors 16 ECC Bytes 65 Unformatted Capacity 76319 MB ATA Standard ATA/ATAPI-7 ATA Device Features: 48-bit LBA Supported Advanced Power Management Not Supported Automatic Acoustic Management Supported, Disabled Device Configuration Overlay Supported DMA Setup Auto-Activate Not Supported General Purpose Logging Supported Host Protected Area Supported, Enabled In-Order Data Delivery Not Supported Native Command Queuing Not Supported Phy Event Counters Supported Power Management Supported, Enabled Power-Up In Standby Not Supported Read Look-Ahead Supported, Enabled Release Interrupt Not Supported Security Mode Not Supported SMART Supported, Enabled SMART Error Logging Supported SMART Self-Test Supported Software Settings Preservation Supported, Enabled Streaming Not Supported Tagged Command Queuing Not Supported Write Cache Supported, Enabled SSD Features: Data Set Management Not Supported Deterministic Read After TRIM Not Supported TRIM Command Not Supported --------[ SMART ]------------------------------------------------------------------------------------------------------- [ WDC WD2500KS-00MJB0 (WD-WCANKJ194658) ] 01 Raw Read Error Rate 51 200 200 0 OK: Value is normal 03 Spinup Time 21 253 213 2308 OK: Value is normal 04 Start/Stop Count 0 97 97 3186 OK: Always passes 05 Reallocated Sector Count 140 200 200 0 OK: Value is normal 07 Seek Error Rate 51 200 200 0 OK: Value is normal 09 Power-On Time Count 0 83 83 12743 OK: Always passes 0A Spinup Retry Count 51 100 100 0 OK: Value is normal 0B Calibration Retry Count 51 100 100 0 OK: Value is normal 0C Power Cycle Count 0 97 97 3184 OK: Always passes BE Airflow Temperature 45 75 53 25 OK: Value is normal C2 Temperature 0 125 103 25 OK: Always passes C4 Reallocation Event Count 0 200 200 0 OK: Always passes C5 Current Pending Sector Count 0 200 200 0 OK: Always passes C6 Offline Uncorrectable Sector Count 0 200 200 0 OK: Always passes C7 Ultra ATA CRC Error Rate 0 200 200 3 OK: Always passes C8 Write Error Rate 51 200 200 0 OK: Value is normal [ WDC WD800JD-22LSA0 (WD-WMAM9D811607) ] 01 Raw Read Error Rate 51 200 200 0 OK: Value is normal 03 Spinup Time 21 168 165 2591 OK: Value is normal 04 Start/Stop Count 0 96 96 4389 OK: Always passes 05 Reallocated Sector Count 140 200 200 0 OK: Value is normal 07 Seek Error Rate 51 200 200 0 OK: Value is normal 09 Power-On Time Count 0 76 76 17919 OK: Always passes 0A Spinup Retry Count 51 100 100 0 OK: Value is normal 0B Calibration Retry Count 51 100 100 0 OK: Value is normal 0C Power Cycle Count 0 96 96 4387 OK: Always passes BE Airflow Temperature 45 78 42 22 OK: Value is normal C2 Temperature 0 121 85 22 OK: Always passes C4 Reallocation Event Count 0 200 200 0 OK: Always passes C5 Current Pending Sector Count 0 200 200 0 OK: Always passes C6 Offline Uncorrectable Sector Count 0 200 200 0 OK: Always passes C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passes C8 Write Error Rate 51 200 200 0 OK: Value is normal Link to comment Share on other sites More sharing options...
