Stevie D Posted March 30, 2010 Share Posted March 30, 2010 Hi, I am running CCleaner 2.30 on a Windows 7 64 bit machine. When I click on the System Restore tool, instead of bringing up a list of my restore points, my system hangs with the spinning circle...not all of the time, but more than half the time. This also happened on 2.29. I tried to unintsall and re-install, but it is still a problem that causes me to have to re-boot after lengthy delays. Link to comment Share on other sites More sharing options...
Alexis Posted March 31, 2010 Share Posted March 31, 2010 How much space have you allocated for System Restore and how long do you keep them? I have noticed that it takes quite a bit longer to load that particular section when there are more restore points on the list. Link to comment Share on other sites More sharing options...
Stevie D Posted March 31, 2010 Author Share Posted March 31, 2010 How much space have you allocated for System Restore and how long do you keep them? I have noticed that it takes quite a bit longer to load that particular section when there are more restore points on the list. I have 9GB maximum allocated and half of it is currently used. I probably have only 2 or 3 points in there. Link to comment Share on other sites More sharing options...
Alexis Posted April 10, 2010 Share Posted April 10, 2010 Hm, perhaps is the is amount of data you are keeping and not the number of restore points. I am very confused about this myself, because I have it turned off on my Windows 7 machine with 0 bytes allocated, but CCleaner is still showing 2 Windows Update restore points. Link to comment Share on other sites More sharing options...
