mike42 Posted January 13, 2009 Share Posted January 13, 2009 I have pointed out this problem earlier, but in the latest build the problem still remains: If I put an entry into winapp2.ini like: "FileKey1=E:\Temp|foo.bar|RECURSE" or "FileKey1=E:\Temp|foo.*|RECURSE" any foo.bar file in a subfolder will not be found and cleaned (say E:\Temp\mystuff\foo.bar). However "FileKey1=E:\Temp|*.bar|RECURSE" does find the file in subfolders. So RECURSE works only, if the filename is a wildcard??? Moreover "FileKey1=E:\Temp|foo.*|RECURSE" will clean any subfolder called "foo" entirely. Is this behavior intended or is it a bug? Thanx for listening, Mike Link to comment Share on other sites More sharing options...
