JonfromCB Posted April 3, 2008 Share Posted April 3, 2008 Any help to this almost computer illiterate would be most appreciated. I used CCleaner after a popup announcing a "systems error!"....your computer was infected by unknown trojan.....click OK to download the antispyware program to clean you system (recommended)" I immediately ran my Norton system scan which quaranteened the bug, but did not get rid of the popup described above, so I downloaded and ran CCleaner with no success. How can I get rid of the popup and be sure the adware/spyware is also gone? Thanks Link to comment Share on other sites More sharing options...
fredvries Posted April 3, 2008 Share Posted April 3, 2008 This problem is often caused by a trojan or a rogue spyware program. Please download and run Malwarebytes' Anti-Malware here and report if your problems are gone. Link to comment Share on other sites More sharing options...
Tarq57 Posted April 3, 2008 Share Posted April 3, 2008 Another that might well help, from the same company, is Rogue remover. Some names the files your AV detected, and perhaps a screenshot of the popup, might help. Some of these rogue programs are a right pain to remove. Link to comment Share on other sites More sharing options...
