BarbiD Posted February 20, 2008 Share Posted February 20, 2008 Hello - I installed the latest version of CCleaner on a Win XP Pro SP2 laptop and each time I tried to run it, it gave me this error 'CCleaner has encountered a problem and needs to close.' I tried running it from a flash drive and got the same message. It runs fine on my PC. I downloaded the Visual Basic SP6 that I saw might help in another post but no luck. Any suggestions? Thank you. Link to comment Share on other sites More sharing options...
davey Posted February 20, 2008 Share Posted February 20, 2008 Hello BarbiD, Below is extract from another members testing.Give it a try for now. Let us know how it goes. Good Luck, davey I had the same problem, solved it by unchecking all deletion boxes then enabling them one at a time, run cleaner until I found the culprit (in my machine anyhow). It was Windows log files for whatever reason. I left this unchecked and now CC works fine in any mode. Try that, it may be a similar problem. Link to comment Share on other sites More sharing options...
