Tom AZ Posted August 3, 2007 Share Posted August 3, 2007 I noticed today that my computer was a little sluggish. I opened the task bar to find that my "System Idle Process" CPU usage was running at 98-99. Is this normal? What could be causing this and how do I correct it? Link to comment Share on other sites More sharing options...
Glenn Posted August 3, 2007 Share Posted August 3, 2007 It's perfectly normal if nothing else is running. It's not a real process, it shows the idle (unused) CPU time. Link to comment Share on other sites More sharing options...
Tom AZ Posted August 3, 2007 Author Share Posted August 3, 2007 It's perfectly normal if nothing else is running. It's not a real process, it shows the idle (unused) CPU time. That's a relief to know-- thanks. Link to comment Share on other sites More sharing options...
