dmach8 Posted February 22, 2010 Share Posted February 22, 2010 I did a search and saw that someone had this issues with windows 7 and it cleared up, I have had several restarts and it hasnt changed and I have restore points going through the system restore.. This is on windows Xp Link to comment Share on other sites More sharing options...
Ishi Posted February 23, 2010 Share Posted February 23, 2010 I have read a similar complaint but I think that was either on Windows Vista or Windows 7. I think you have to enable a few Windows services to make the restore points appear. If they are disbled, the restore points will not appear or work. Go to Run in the Start Menu and type services.msc. Make sure that all the services there, related to restore points are enabled. In my knowledge these would be the services called Microsoft Software Shadow Copy Provider and Volume Shadow Copy. Not sure if you have those in Windows XP though but good to have a look. They should be enabled. I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
dmach8 Posted February 23, 2010 Author Share Posted February 23, 2010 I have both of those, they are both set to manual. Link to comment Share on other sites More sharing options...
Ishi Posted February 24, 2010 Share Posted February 24, 2010 Try setting them to "Automatic" and restart the computer so it takes effect. I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
dmach8 Posted February 24, 2010 Author Share Posted February 24, 2010 Ok I did that, they were also stopped. Rebooted first, none showed in Ccleaner so i started them both and still none show, Still go though windows system restore i can see them daily and when windows updates. Link to comment Share on other sites More sharing options...
Ishi Posted February 24, 2010 Share Posted February 24, 2010 If you can't see any restore points if you use Window's own module of selecting restore points, why not create a new one??? Otherwise if your system is OK at the moment, there is little point of doing a system restore so you can create a new one today instead It is possible to manually create one. I have already experienced system restore points disappearing in CCleaner and that is because there are NO more restore points available because Windows have automatically deleted them since the space allocated for restore points have now been filled. I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
dmach8 Posted February 25, 2010 Author Share Posted February 25, 2010 I can see them in windows own module, there are ones for every day or a couple if updates were performed, my question is why none show up in ccleaner? There is a busy display when you click to display them in ccleaner but it doesnt display any. Its like windows or something is hiding them from ccleaner if that makes sense.. I did every thing as mentioned above and it hasnt helped, my friends desktop with xp he says he can see restores with the same vs of CCleaner... Would a virus program, antispyware control this? Thanks Link to comment Share on other sites More sharing options...
Ishi Posted February 25, 2010 Share Posted February 25, 2010 I don't think this the work of some spyware or virus. Then this is definitely a bug. Why not uninstall CCleaner then reinstall it again??? Or you can try an earlier version such as v.2.26 and 2.27. They won't have much difference from v.2.28 anyway. If this is the case, I am beginning to suspect that the latest versions of CCleaner do have bugs with Windows XP even though they have been especially built for compatibility to Windows 7. I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
dmach8 Posted February 25, 2010 Author Share Posted February 25, 2010 I tried uninstalling and reinstalling and no help, i havent rolled back.. Link to comment Share on other sites More sharing options...
Ishi Posted February 25, 2010 Share Posted February 25, 2010 Then do a roll back please and see if that helps. I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
dmach8 Posted February 25, 2010 Author Share Posted February 25, 2010 Ok, Well I had turned off system restore this AM , turned it back on this evening and it showed the first one as it should greyed out, so i made another and it it displayed them both with the oldest being able to delete as it should be. The wierd thing is I have tried this before, but it may be the combination of the other services? Thanks again Link to comment Share on other sites More sharing options...
