alcanh Posted October 23, 2009 Share Posted October 23, 2009 I tried to install the latest version of Recuva and was stopped by my computer's DEP function. It says Recuva is trying to access memory locations dedicated for only Windows to access. I am running the latest update to XP-Pro. on an Acer Aspire 5112WLMi Please advise how I can get this software to work. Thank you in advance. Link to comment Share on other sites More sharing options...
marmite Posted October 24, 2009 Share Posted October 24, 2009 That's interesting; I've never seen anyone post here about DEP issues. If you have a look at this article it tells you how to configure DEP through the boot.ini file and/or through Control Panel / System / Advanced tab / Performance settings. This article is slightly more technical. Just consider that any changes that you make could have wide implications - and I'd be a little concerned that you're getting this problem simply by trying to install recuva. Do you get the same problem deploying the portable version? Link to comment Share on other sites More sharing options...
kyy Posted October 25, 2009 Share Posted October 25, 2009 I wouldn't use any software that is stopped by DEP detection. The last I'd do is to touch the DEP settings to get a faulty software working. I'd give Restoration a try first. You can download it here: http://tinyapps.org/downloads/rest2514.exe Link to comment Share on other sites More sharing options...
marmite Posted October 25, 2009 Share Posted October 25, 2009 I wouldn't use any software that is stopped by DEP detection. The thing that did occur to me afterwards was whether the OP had downloaded a kosher version of recuva. The last I'd do is to touch the DEP settings to get a faulty software working. And of course the kosher version of recuva isn't 'faulty software'. But it's not unknown for perfectly 'good' software to have DEP compatibility issues ... I'm sure I've encountered it before. It's a case of being sure of the provenance of your software and then not compromising the rest of your system if you choose to make an exception for it. I guess really the issue here is the particular installer the OP is running ... @alcanh ... where did you download it from? Link to comment Share on other sites More sharing options...
BeekhuisJH Posted November 24, 2009 Share Posted November 24, 2009 I tried to install the latest version of Recuva and was stopped by my computer's DEP function. It says Recuva is trying to access memory locations dedicated for only Windows to access. I am running the latest update to XP-Pro. on an Acer Aspire 5112WLMiPlease advise how I can get this software to work. Thank you in advance. I have been running into the same problem, i found out that the version 1.26 is the last version of recuva, on which DEP is not complaining on my machine (HP dc7600) Link to comment Share on other sites More sharing options...
