Mickel Posted June 16, 2009 Share Posted June 16, 2009 The Thumbnails from GIMP (in XP C:\Documents and Settings\.thumbnails) useing much storage after some work with picture. Can you please add a function to delte these little images? Thanks Link to comment Share on other sites More sharing options...
Moderators DennisD Posted June 16, 2009 Moderators Share Posted June 16, 2009 Hi Mickel, and welcome to Piriform. If you download and place CCleaners Winapp2.ini in the CCleaner "Program Files" folder, you'll find that particular area is covered. http://forum.piriform.com/index.php?showtopic=1110 (Zip download at the end of first post) Once in place, when you next open CCleaner, you'll find some new asterisked items showing under "Applications". These are the Winapp2.ini entries. Hope that helps. Link to comment Share on other sites More sharing options...
Mickel Posted June 17, 2009 Author Share Posted June 17, 2009 Thanks DennisD and sorry for my bad english ::. i come from austria Link to comment Share on other sites More sharing options...
Moderators DennisD Posted June 18, 2009 Moderators Share Posted June 18, 2009 Thanks DennisD and sorry for my bad english ::. i come from austria Mickel, you're English is a lot better than my Austrian, so no apology needed. Link to comment Share on other sites More sharing options...
