13 hours ago, Winapp2.ini said:<div class="ipsQuote_contents"> <p> Is there any reason why you would want to clean one but not the other at the same time? </p> </div>
Windows Start and Start Menu Cache are two different things.
Modified entry: [Windows Spotlight *]
Change the Detect so that this module does not show up in Windows 10 or other systems that do not have IrisService entry in the registry.
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\IrisService
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\IrisService\Cache
9 hours ago, SMalik said:<div class="ipsQuote_contents"> <p> Windows Start and Start Menu Cache are two different things. </p> </div>
What is the difference between Windows Start and the Windows Start Menu? It seems like Windows Start is just the subsystems responsible for the menu's functions in this case?
On 02/07/2024 at 01:14, siliconman01 said:<div class="ipsQuote_contents"> <p> Modified entry: <strong>[Windows Spotlight *]</strong> </p> <p> Change the Detect so that this module does not show up in Windows 10 or other systems that do not have IrisService entry in the registry. </p> <pre class="ipsCode prettyprint lang-html prettyprinted"><span class="pln">Windows Spotlight *]LangSecRef=3025
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\IrisService\Cache<p> </p> </div>
Windows 10 has this.
On 02/07/2024 at 07:38, Winapp2.ini said:<div class="ipsQuote_contents"> <p> What is the difference between Windows Start and the Windows Start Menu? It seems like Windows Start is just the subsystems responsible for the menu's functions in this case? </p> </div>
Windows Start is where you pin Apps. Windows Start Menu is where programs install shortcuts. Windows keeps a cache of Start Menu shortcuts. Sometimes uninstalled programs leave traces in Start Menu Cache. I think [Windows Start Menu *] entry should be changed to [Windows Start Menu Cache *].
By the way, I don’t have RegKey1 thru RegKey6, on my Windows 10/11 systems.
<p style="color:#382e23;font-size:13px;">
<span>[Windows Start *]</span>
LangSecRef=3025
FileKey1=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\AC|*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\LocalState|*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\TempState|*|RECURSE
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage|ProgramsCache
RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2|ProgramsCache
RegKey3=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2|ProgramsCacheSMP
RegKey4=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2|ProgramsCacheTBP
RegKey5=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage|ProgramsCache
RegKey6=HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage|ProgramsCache
On 05/07/2024 at 09:20, SMalik said:<div class="ipsQuote_contents"> <p> Windows 10 has this. </p> </div>
My Windows 10x64 Pro (Version 22H2 (OS Build 19045.4598) does not have it. So I continue to recommend the change to [Windows Spotlight *]. ?
On 05/07/2024 at 10:43, SMalik said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <div style="font-size:13px;"> <p style="color:#382e23;font-size:13px;"> By the way, I don’t have RegKey1 thru RegKey6, on my Windows 10/11 systems. </p> <p style="color:#382e23;font-size:13px;"> <span>[Windows Start *]</span> </p> <p style="color:#382e23;font-size:13px;"> LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows FileKey1=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\AC|*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\LocalState|*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\TempState|*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage|ProgramsCache RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2|ProgramsCache RegKey3=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2|ProgramsCacheSMP RegKey4=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2|ProgramsCacheTBP RegKey5=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage|ProgramsCache RegKey6=HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage|ProgramsCache </p> </div> </div>
I have RegKey1 on Windows 10 Home v22H2, it has this in it (which doesn't look like anything worth cleaning):
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartPage]
"StartMenu_Start_Time"=hex:67,da,a1,ba,2b,0b,d7,01
"Start_JumpListModernTime"=hex:e9,17,96,5d,06,1e,d4,01
New
[Energy Reports *]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Windows
FileKey1=%WinDir%\System32\|battery-report.html;energy-report.html
8 hours ago, Andavari said:<div class="ipsQuote_contents"> <p> New </p> <p> [Energy Reports *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Windows FileKey1=%WinDir%\System32\|battery-report.html;energy-report.html </p> </div>
would it be appropriate to merge this with Windows Power Efficiency Diagnostics?
Put them with whatever other cleaner you want, I just posted for the file paths to clean them.
Those reports aren't automatically created by Windows anyways, someone has to manually invoke them via a PowerCFG command prompt.
what is this program/windows-part(?)?
[Squirrel.Windows *]
LangSecRef=3021
DetectFile=%LocalAppData%\SquirrelTemp
FileKey1=%LocalAppData%\SquirrelTemp|*|REMOVESELF
8 minutes ago, Nergal said:<div class="ipsQuote_contents"> <p> what is this program/windows-part(?)? </p> <pre class="ipsCode prettyprint lang-html prettyprinted"><span class="pln">[Squirrel.Windows *]LangSecRef=3021
FileKey1=%LocalAppData%\SquirrelTemp|*|REMOVESELF<p> </p> </div>
Quote<div class="ipsQuote_contents"> <p style="margin-top:0px;color:rgb(230,237,243);font-family:'-apple-system', BlinkMacSystemFont, 'Segoe UI', 'Noto Sans', Helvetica, Arial, sans-serif, 'Apple Color Emoji', 'Segoe UI Emoji';font-size:16px;font-style:normal;font-weight:400;letter-spacing:normal;text-indent:0px;text-transform:none;word-spacing:0px;white-space:normal;background-color:rgb(13,17,23);text-decoration-thickness:initial;text-decoration-style:initial;"> Squirrel is both a set of tools and a library, to completely manage both installation and updating your Desktop Windows application, written in either C# or any other language (i.e., Squirrel can manage native C++ applications). </p> <p style="margin-top:0px;color:rgb(230,237,243);font-family:'-apple-system', BlinkMacSystemFont, 'Segoe UI', 'Noto Sans', Helvetica, Arial, sans-serif, 'Apple Color Emoji', 'Segoe UI Emoji';font-size:16px;font-style:normal;font-weight:400;letter-spacing:normal;text-indent:0px;text-transform:none;word-spacing:0px;white-space:normal;background-color:rgb(13,17,23);text-decoration-thickness:initial;text-decoration-style:initial;"> Squirrel uses NuGet packages to create installation and update packages, which means that you probably already know most of what you need to create an installer. </p> </div>
https://github.com/Squirrel/Squirrel.Windows
Squirrel is a component of a variety of different applications and is used for staging updates and installations
7 hours ago, Winapp2.ini said:<div class="ipsQuote_contents ipsClearfix" data-gramm="false"> <p> <a href="https://github.com/Squirrel/Squirrel.Windows" rel="external nofollow" target="_blank">https://github.com/Squirrel/Squirrel.Windows</a> </p> <p> </p> <p> Squirrel is a component of a variety of different applications and is used for staging updates and installations </p> </div>
Ah so, for instance, it's used for discord when it does its updating speil when i (rarely) launch it. Makes sense that discord was very prevalent in the log the entry wanted to clean. I'll check that for cleaning definitly
Seems that Microsoft Onedrive and Microsoft Onedrive* have partly the same files to be deleted. Might be nice if the "*" had the one in the non "*" removed...
8 hours ago, CSGalloway said:<div class="ipsQuote_contents"> <p> ... Might be nice if the "*" had the one in the non "*" removed... </p> </div>
Please read Winapp2.ini's reply to this topic:
<a href="<___base_url___>/topic/32310-winapp2ini-additions/?do=findComment&comment=349426" rel="">https://community.ccleaner.com/topic/32310-winapp2ini-additions/?do=findComment&comment=349426</a>
[Microsoft OneDrive]
ID=2396
LangSecRef=3021
LangRef=9251
Detect=HKCU\Software\Microsoft\SkyDrive
Detect2=HKCU\Software\Microsoft\OneDrive
Detect3=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.microsoftskydrive_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\microsoft.microsoftskydrive_8wekyb3d8bbwe
Default=True
FileKey1=%LocalAppData%\Microsoft\SkyDrive\logs|*.log;*.etl
FileKey2=%LocalAppData%\Microsoft\OneDrive\setup\logs|*.log;*.aodl;*.odl;*.otc
FileKey3=%LocalAppData%\Microsoft\OneDrive\logs\Personal|*.loggz;*.etl;*.odlsent;*.aodl;telemetry-dll-ramp-value.txt;telemetryCache.otc.session;telemetryCache.otc-wal;telemetryCache.otc
FileKey4=%LocalAppData%\Microsoft\OneDrive\logs\ListSync\Business1|*.ODL;*.txt;*.ODLGZ;*.otc
FileKey5=%LocalAppData%\Microsoft\OneDrive\logs\Common|*.ODL;*.txt;*.aodl;*.otc
FileKey7=%LocalAppData%\OneDrive\cache\qmlcache|*.qmlc
FileKey8=%LocalAppData%\Packages\microsoft.microsoftskydrive_8wekyb3d8bbwe\AC\Microsoft\CryptnetUrlCache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\microsoft.microsoftskydrive_8wekyb3d8bbwe\AC\TokenBroker\Cache|*.tbres
FileKey10=%LocalAppData%\Packages\microsoft.microsoftskydrive_8wekyb3d8bbwe\LocalState\logs|*.log
FileKey11=%LocalAppData%\Packages\microsoft.microsoftskydrive_8wekyb3d8bbwe\AC\INetCache|*.*|RECURSE
[Microsoft OneDrive *]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\OneDrive
DetectFile=%LocalAppData%\Packages\microsoft.microsoftskydrive_*
FileKey1=%LocalAppData%\Microsoft\OneDrive\Logs|*|RECURSE
FileKey2=%LocalAppData%\Microsoft\OneDrive\Setup\Logs|*|RECURSE
FileKey3=%LocalAppData%\Microsoft\Windows\OneDrive\logs|*|RECURSE
FileKey4=%LocalAppData%\OneDrive\Cache|*|RECURSE
FileKey5=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC|*|RECURSE
FileKey6=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\LocalCache|*|RECURSE
FileKey7=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\LocalState\Logs|*.log
FileKey8=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\Settings|*.log*
FileKey9=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\TempState|*|RECURSE
FileKey10=%ProgramFiles%\Microsoft OneDrive\Setup\Logs|*
FileKey11=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\OneDrive\Logs|*|RECURSE
FileKey12=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\OneDrive\Setup\Logs|*|RECURSE
FileKey13=%WinDir%\System32\LogFiles\CloudFiles|*|RECURSE
FileKey14=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\OneDrive\Logs|*|RECURSE
FileKey15=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\OneDrive\Setup\Logs|*|RECURSE
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.microsoftskydrive_8wekyb3d8bbwe\PersistedPickerData\microsoft.microsoftskydrive_8wekyb3d8bbwe!Microsoft.MicrosoftSkyDrive\DefaultOpenFileMultiple|LastLocation
RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.microsoftskydrive_8wekyb3d8bbwe\SearchHistory
what are the entries in OneDrive* that are NOT in Onedrive?
Feel free to remove the commented section, I'm posting this as-is as it appears in my winapp2.ini file.?
Samsung Magician updated to support cleaning version 8 which seems like parts of it are more of a Chromium browser now.
Added:
FileKey1, FileKey2, FileKey3, FileKey13
[Samsung Magician *]
; Info: Removes the setup file that it duplicates during setup, and the
; huge 1GB 'mict.dat' benchmark file in the root of disk drives you
; had it benchmark. Also removes cache and logs.
; Notes: You can't modify this cleaning routine to remove language
; files, doing so breaks Samsung Magician and it must be re-installed
; 'Migration Service' and 'Samsung Magician Service' cache, logs,
; etc., are impossible to clean when those two services are running.
; Go into Windows 'Services.msc' and set 'CMigrationService' and
; 'SamsungMagicianSVC' to the Manual startup type, and then restart
; the PC. Now CCleaner is able to clean Samsung Magician.
LangSecRef=3024
Detect=HKLM\Software\Samsung Magician
FileKey1=%AppData%\Samsung Magician\Cache\Cache_Data|*.*|RECURSE
FileKey2=%AppData%\Samsung Magician\Code Cache|*.*|RECURSE
FileKey3=%AppData%\Samsung Magician\DawnCache|*.*|RECURSE
FileKey4=%AppData%\Samsung Magician\GPUCache|*.*|REMOVESELF
FileKey5=%AppData%\Samsung Magician\Local Storage\leveldb|*.old
FileKey6=%AppData%\Samsung Magician\Network|*.*
FileKey7=%AppData%\Samsung Magician\Session Storage|*.old
FileKey8=%CommonAppData%\Samsung\Backup|*.exe
FileKey9=%CommonAppData%\Samsung\Samsung Magician|*.exe|RECURSE
FileKey10=%CommonAppData%\Samsung\Samsung Magician\PB|*.txt
FileKey11=%ProgramFiles%\Samsung Magician\Logs|*.*
FileKey12=%ProgramFiles%\Samsung\Samsung Magician\Log*|*.*
FileKey13=%ProgramFiles%\Samsung\Samsung Magician\MigrationService|*.log
FileKey14=%ProgramFiles%\Samsung\Samsung Magician\MigrationService\Logs|*.*
FileKey15=%SystemDrive%\MagicianPerf*|*.*|REMOVESELF
RegKey1=HKCU\Software\Local AppWizard-Generated Applications\SamsungMagician
Re-post with some changes.
Samsung Magician updated to support cleaning version 8.
Added:
ExcludeKey1, ExcludeKey2, FileKey1, FileKey2, FileKey3, FileKey13.
Changed:
FileKey4 changed REMOVESELF to RECURSE.
; Notes: You can't modify this cleaning routine to remove language files,
; doing so breaks Samsung Magician and it must be re-installed.
LangSecRef=3024
ExcludeKey1=FILE|%AppData%\Samsung Magician\|Local State
ExcludeKey2=FILE|%AppData%\Samsung Magician\|Preferences
FileKey4=%AppData%\Samsung Magician\GPUCache|*.*|RECURSE
Good afternoon.
Nothing since this new community, winapp2 moved elsewhere?
Is there a newer version available somewhere?
TIA! ::
