Winapp2.ini additions
Perhaps give the person who compiles it a shout and see if they post.
@Winapp2.ini
I know he’s been on since the conversion, in other topics. I think they’ve moved most of the conversation to github
However it looks like the most current commit was 6 months ago.
BUG REPORT: CCleaner Winapp2.ini deletes all saved Firefox passwords when “Saved Passwords” is UNchecked but “Firefox Saved Logins” is checked. I tested & recreated this in Windows 10 several times.
I am upset that my long list of important passwords were deleted. Deleting “Firefox Saved Logins” should not delete my Firefox password list. There is NO warning written anywhere that says checking “Firefox Saved Logins” will delete all of my passwords. That is what checking “Saved Passwords” is for. This is unacceptable. I have used CCleaner for years & checking “Firefox Saved Logins” never deleted my saved password list before.
Please fix this problem, make the description more clear or add a warning popup at least… This setting of ALL settings is unclear & deserves a warning popup…
For clarity so you don’t have to ask: Yes, I have actually lost all my saved passwords. No, I am not just being logged out of sites or sessions. When I go to Saved Passwords in Firefox Settings, my passwords get deleted when I check “Firefox Saved Logins” & then clean.
Sorry to say, but this is the intended behavior. The Firefox Saved Logins entry in winapp2.ini overlaps with the Saved Passwords entry in the Firefox section of CCleaner.
“Logins” is the word that Mozilla uses to refer to the username+password combinations saved in the password manager
{Question moved into winapp2 dedicated thread - Mod).
I am trying to delete the VLC INI File with the CCleaner Custom Clean. I understand that this should be possible with WINAPP2.
The section in the WINAPP2.INI is:
[myVLC *]
LangSecRef=3023
DetectFile=%AppData%\vlc\vlc-qt-interface.ini
FileKey1=“C:\Users\peter\AppData\Roaming\vlc\vlc-qt-interface.ini”
“MyVLC” shows up in the Custom Clean of CCleaner, so obviously WINAPP2 is recognized by CCleaner.
But the VLC INI file is not deleted. I wonder why.
I just figured it out myself:
FileKey1=C:\Users\peter\AppData\Roaming\vlc|vlc-qt-interface.ini
Replacing the Backslash by a Vertical Bar does the trick.
hey, I know about winapp2 but do not know to edit it. I struggle in registry key set. Please help me.
