oh yes thanks hazelnut
ublock v1.4.0
gorhill released this
3 days agoNotes:
This version will be uploaded to the Chrome and Opera store. However it needs to be approved before being available, so expect it to appear early next week.
New: Ability to use Adguard filter listsYou can now directly use Adguard filter lists. Filters which use Adguard-specific filter syntax extension will simply be discarded by uBO. If you want to use an Adguard filter list, you will have to import it as an external filter list.
PopundersA new filter type is introduced: popunder. This gives uBlock Origin the ability to block popunders. Popunders are when a web page opens a new legitimate content in another tab or window, while at the same time loading nuisance content in the current tab. They are essentially the reverse of what is happening with nuisance popups, where the nuisance content is opened in a new tab or window.
Since the popunder option is specific to uBO, any instance of sites using popunders will have to be reported here so that filters can be crafted to address the issue for those sites.
Closed as fixed: Firefox
- NoScript Force HTTPS feature interferes with uBlock Origin
- Default browser font does not work well for dynamic filtering panel
uBlock Origin breaks custom toolbars in Palemoon
- Possibly related: [seaMonkey] Filter list is empty after browser restart
- Site disables uBlock Origin's own style tags
- [Pull request] Add YousList as a Korean third party filter
- Element picker: a selected element with width or height of zero should fall back on dimensions of child elements
- End "My filters" list with empty line
- Cosmetic filter fails to hide element
- The white list is invalid
- uBo is causing CPU hog with imdb.com (popup video)
- Support subscribe links
- Block ad videos playing automatically
- Fixed issue arising from Add the I don't care about cookies filter to Regions, languages? (see comment).
