Preventing Ccleaner 7 from auto-loading at startup - - how? Can't find setting. Thanks
Preventing Ccleaner 7 from auto-loading at startup - - how? Can’t find setting in ver. 7 to prevent auto-startup. Thanks
I’m not sure that you can, see:
I use “Autorun Organizer v.6.20” to disable “startup” programs in Windows. It is a freebie for ChemTable.
It will allow you to remove programs, delay programs and disable them - even CCleaner v.7 :rofl:.
It is one of my essential utilities. An important part of my Saturday morning system clean-up. Also on that list is “Reg Organizer” - a paid-for application from the same creator - worth EVERY penny :smiley: .
I have been using both for many years without any problems.
thank you for this information
thank you
