Prevent Cleaner 7 from opening on PC startup
Hi ! Cleaner 7 has just been installed on my computer and I can’t stop it from opening when the PC starts up. I can’t find the function in the application. Ccleaner 7 doesn’t appear in the task manager. It’s disabled in the task scheduler library. And yet it opens every time I start up! How can I stop it ? Thank you.
Look at the ‘BackGround apps’ in Task Manager for CCleaner Services.
From what I can gather though v7 is designed to be always running as a background task.
I haven’t had time to take a good look at it yet, but I’d suggest looking to see if there is a shortcut to it in the Windows ‘Startup’ folder.
Thanks for your reply. CCleaner doesn’t appear in “Background apps” in Task Manager for CCleaner services. It’s annoying if it’s forced to run in the background… I wish I knew that before it installed the update.
Is there a reason that you are posting using 3-dot tags?
Maybe it’s copy/pasted from a different text editor?
It makes your posts difficult to read unless/until I edit your post to remove them.
not understood
Don’t worry about it, it was just a formatting oddity.
Since CC Cleaner is not in Task Manager, how can I prevent it from automatically downloading and installing every time I open an earlier version?
I’m not sure why you think Task Manager has anything to do with updating?
To prevent the automatic updating of an earlier version then turn off Automatic Updating in that earlier version, by unticking it.
eg:
@nukecad Q Is about v7, Your red circle is about V6.
I tried open taška manager/ services there set to manual start, after restart Cc is running, but services show stoped
I Will try some stuff, then I Will return to v6 or other app. I loved Cc but this is disgusting.
Be pation please with my eng. Thx
P.S. v7 must go out od my PC. I shuted Down cc7 service and it resurrect like virus. Hope I find v6
For the download link(s) and roll back instructions click this: How to Roll Back from v7 to v6.39
(PS. Yes the red circle is indeed in V6, because it was answering the question that srbuckeye65 asked which was how to prevent v6 updating to v7).
