I think CCleaner is better than all of those programs you listed. easy cleaner can do all of the things CCleaner does and more but It can also harm your pc with things such as the registry cleaner and duplicate file cleaner. I have never used cyberscrub or eraser but they probably do about the same thing. I would stick with CCleaner and abandon the others if you want to be 100% problem free.
Cyberscrub and eraser are not exactly for cleaning a PC, with the intentions of helping speed it up by removing the clutter that accumalates like CCleaner does.
They are for removing files and folders in a secure way rather than just deleting them.
When windows deletes a file, it is not actually deleted, it is marked as free space ready for over writing. All the while it is marked for deletion it can be found by a recovery tool, and even after it has been over written it may still be possible to recover it.
Cyberscrub and eraser over write files, when deleting, many numbers of time to ensure that they are erased beyond recovery. Although I dont think they over write them to recommended standards as some other "shredder" type programs do.
Hope this helped a little bit, and welcome to the forum.
I use EasyCleaner as a registry cleaner, it's never caused any problems. But you should stay away from its "Duplicates" scan, reliable sources say it can cripple Windows.
The only problem that I ever had was when it deleted a registry entry that related to windows help, that was in version 1.7, as soon as the creator realised what he had done he created a fix which could be downloaded from the easycleaner website. this restored the registry entry and all was well again.
I've never had any problems with the registry cleaner. I haven't tried the duplicates scan though, on MajorGeeks forum one of their experts said it was dangerous, and in the program itself it says much the same thing. Something like, you need specialized knowledge to tell which entries are safe to delete. So I won't touch it.
I think this is true of any program that cleans out duplicate files, I only ever did it once using system mechanic a long time ago, had to reinstall everything, I learnt my lesson, and have never done it since.
You'll must have been lucky with the registry cleaner. Because I used regseeker once on a win 98 se machine and I had to reinstall windows. Now the only program I let touch my registry is the CCleaner.
I run easycleaner's registry cleaner on various machines once a week and never have problems, this is in addition to running CCleaner numerous times a day.
