Apologies for the downtime over the last two days. We had a hack attempt which resulted in the decision to take the Forum offline until the problem was solved. IPB have just released a patch for the forum software, so we're back, fully protected!
I'd also like to reassure you that no user data was compromised during this time.
Thanks for understanding, and keep enjoying our software
Having real difficulty signing in, only way I can sign in is if I DON'T use the forum main page to sign in from. In other words if I go for example to the Software page of the forum I can sign in there
Keep getting signed out if I refresh the page.
Cannot go to a thread and copy the link to paste elsewhere, it just shows link for main forum page in address bar instead of thread link.
(testing smilies Okay now but cannot view smiles made in posts before the forum went down)
Little dropdown arrow next to member name on top right-hand side of page is missing.
Seems to be evolving as we write. For a moment the messenger and notifications buttons were present but not visible, the whole bar was the same color. Then they were there. Now they're not. Looks like they aren't there if writing a post but they are if just reading one No idea what that menas, hope it helps.
It seems that at the top level of the forums the messenger and notifications buttons are visible.
http://ccleaner.ipbhost.com/index.php?act=idx
At the next level down, "Announcements" (Piriform Community Forums ---> General ---> Announcements) they are visible,
http://ccleaner.ipbhost.com/index.php?showforum=5
But at the next level down "Forum Downtime" (Piriform Community Forums ---> General ---> Announcements ---> Forum Downtime) they are not visible, but they are there.
I know that I posted this already in a different thread but all of my shortcuts to the Piriform forum don't work any more. And I have two scrollbars on the right hand side of the computerscreen when I visit the forum.
Edit:
1. Scrollbar issue seems to be solved.
2. Webadresses all have changed. No wonder my Favourite Piriform shortcuts don't work any more. Any plans to use the old webadresses again ?
3. Notification system seems to be working as it should.
