Ccleaner alpha test has ended
I could do nothing but close this window. Dose anybody encounter this, how do you resolve this problem. Thanks.
From what I can see in your screenshot then you need to do this:
I really appreciate your help. I followed your steps and it seems something wrong happened. I try to search and find ways to resolve the problems but failed. Here are some more screenshots.
The warning says Ccleaner 7 services on the local computer started and then stoped. some services will stop automatically if not used by other services or programs.
C:\Program Files\Piriform\CCleaner 7\log\ccleaner_modules.log
   Exception: Request error. WinHTTP error code: 12007. '无法解析服务器的名称或地址'
        Code: 0x00002ee7 (12007)
[2025-11-03 01:51:44.423] [notice ] [settings ] [ 4556: 6932] [B1E1B1: 121] Server is not available, trying to read property from local store
[2025-11-03 01:51:44.427] [info ] [burger ] [ 4556: 6932] [400157: 55] asw::burger_client::RecordSender::Send
Exception: Request error. WinHTTP error code: 12007. ‘无法解析服务器的名称或地址’
[2025-11-03 01:51:44.427] [notice ] [settings ] [ 4556: 6932] [B1E1B1: 121] Server is not available, trying to read property from local store
[2025-11-03 01:51:44.431] [info ] [burger ] [ 4556: 6932] [400157: 55] asw::burger_client::RecordSender::Send
[2025-11-03 01:51:44.441] [info ] [prgdeact ] [ 4556: 6932] [C8EF65: 193] [*detail::program_deactivator_module::Run] ProgramDeactivator is running.
[2025-11-03 01:51:44.452] [notice ] [settings ] [ 4556: 6932] [B1E1B1: 121] Server is not available, trying to read property from local store
[2025-11-03 01:51:44.454] [notice ] [settings ] [ 4556: 7544] [B1E1B1: 121] Server is not available, trying to read property from local store
[2025-11-03 01:51:44.454] [info ] [settings ] [ 4556: 7544] [B1E1B1: 242] Property avdef://servers/servers/ShepherdUrl read & cached with origin 5 and code 3
[2025-11-03 01:51:44.454] [info ] [shepsync ] [ 4556: 7544] [53052A: 95] Wait interval 60
[2025-11-03 01:51:44.464] [info ] [prgdeact ] [ 4556: 7216] [086617: 222] [*DBConfigManager::ReloadSecuritySoftware] Security SW reloaded
[2025-11-03 01:51:44.464] [info ] [prgdeact ] [ 4556: 7216] [C8EF65: 176] [*etail::program_deactivator_module::Init] ProgramDeactivator is initialized.
[2025-11-03 01:51:44.464] [info ] [prgdeact ] [ 4556: 7560] [8A5B33: 535] [*ator::detail::CProgramManager::ScanImpl] Scanning..
[2025-11-03 01:51:44.468] [info ] [UsrAccounts] [ 4556: 7560] [993EE4: 542] [*mmon::CUserAccounts::RefreshCurrentUser] Current user SID: S-1-5-18
[2025-11-03 01:51:44.523] [info ] [prgdeact ] [ 4556: 7560] [D0BA59: 48] [*ivator::detail::AppXManager::ReloadAppX] Rescanning AppX (initStartupTasks: false)
[2025-11-03 01:51:44.523] [info ] [prgdeact ] [ 4556: 7560] [086617: 200] [*DBConfigManager::ReloadSecuritySoftware] Reloading Security Software..
[2025-11-03 01:51:44.541] [info ] [prgdeact ] [ 4556: 7560] [086617: 222] [*DBConfigManager::ReloadSecuritySoftware] Security SW reloaded
[2025-11-03 01:51:44.653] [info ] [prgdeact ] [ 4556: 7560] [500F9B: 74] [ceManager::CServiceManager::RefreshList] Scan cancelled
[2025-11-03 01:51:44.653] [info ] [prgdeact ] [ 4556: 7560] [8A5B33: 424] [
::CProgramManagerCollectionThread::main] CProgramManager::ThreadProcImpl() - Scan was cancelled
[2025-11-03 01:51:44.795] [notice ] [settings ] [ 4556: 7276] [B1E1B1: 121] Server is not available, trying to read property from local store
[2025-11-03 01:51:44.801] [info ] [burger ] [ 4556: 7276] [400157: 55] asw::burger_client::RecordSender::Send
C:\Program Files\Piriform\CCleaner 7\log\event_manager.log
[2025-11-06 04:19:57.995] [info ] [burger ] [ 4464: 6600] [400157: 55] asw::burger_client::RecordSender::Send
[2025-11-06 04:19:58.008] [info ] [burger ] [ 4464: 6600] [400157: 55] asw::burger_client::RecordSender::Send
The best that I can suggest is that you uninstall CCleaner7 and go back to using CCleaner v6.39.
How to Roll Back from v7 to v6.39
Follow ALL of the instructions, particularly about turning off the Automatic Updating.
Tons of thank to you :grinning_face:
when I choose to uninstall the cc7, after clicking uninstall button, I see three buttons on the next window, UPDATE, REPAIRE, UNINSTALL. After clicking update button, cc7 woks again.
Fine as long as you are happy with that.
At least if it does go wrong again you now know your options, and how to roll back if you want to.
