CCleaner 6.00/6.01 Portable not Available
At work I am not allowed to install any applications, but I can execute applications that are located in a specific folder.
So I can <strong>only use CCleaner Portable at work</strong>.
Recently version 6.0.9727 of CCleaner was released, but only the installer version.
The portable file name is still ccsetup<strong>592</strong>.zip
So, please release 6.0.9727 also as potable!
Thank you!
OLLI
I've already questioned this and apparently there are a few issues doing a portable of CCleaner v6.00 because of programming changes.
So if you download the portable you will still get v5.92.
I'm told that the issues can be resolved and there should be a v6.01 portable next month.
The portable version is still not available, any idea when it will be released?
Portable skipped this update while they work out folder setup (remember last version's terrible 64bit 32 bit folder that borked portability)
2 hours ago, OLLI_S said:
Portable versions are built out separately to the main releases and may be released some time later, or may skip versions where new functionality needs time to be adapted to the portable configuration. As per the notes above, there will not be a portable version of CCleaner 6.0 this month, but it is likely to resume either with the upcoming CCleaner 6.01 or 6.02.
To confirm, there will not be a portable version of CCleaner 6.01 either, but we are continuing to review how to portable-ize CCleaner 6.02+.
The sticking point is the structural change required for Performance Optimizer although Performance Optimizer would not work properly when the software is being used in a genuinely portable manner.  Although the Portable version is expressly intended "for system admins and advanced users ... not for distribution or mirroring", we know that some third party download sites advertise it as suitable for all users, so we have to make things a little more robust for the general public who may be using Portable contrary to advice.  As such, for the time being we have rolled back the portable version on the website to 5.91 until we can come up with a satisfactory solution.
I'm also looking forward to continued portable releases. At least for me, I'm fine if it doesn't have the Performance Optimizer or Driver Updater or Software Updater, as I'm not planning on using these (much too much "feature creep" for my preference).
In the meantime, I noticed that the portable version v5.92 was replaced with v5.91 on the official ccleaner.com download page. What's the story? Was this intentional? Is there a serious problem with v5.92 (besides the following, which has an easy workaround: https://community.ccleaner.com/topic/62829-592-portable-broken/ )?
51 minutes ago, Pearform said:
		In the meantime, I noticed that the portable version v5.92 was replaced with v5.91 on the official ccleaner.com download page.  What's the story?  Was this intentional?  Is there a serious problem with v5.92 (besides the following, which has an easy workaround: <a href="<___base_url___>/topic/62829-592-portable-broken/" rel="">https://community.ccleaner.com/topic/62829-592-portable-broken/</a> )?
Hi Peaform:
Dave CCleaner's 20-Jun-2022 announcement <above> states that "As such, for the time being we have rolled back the portable version on the website to 5.91 until we can come up with a satisfactory solution ".
There were bigger problems with CCleaner Portable v5.92 than the problem with non-English languages that mogli reported in 5.92 portable broken. See my 04-Jun-2022 post in bgavin's Bug Report: Portable 6.0.0.9727 for Windows about all the unexpected registry entries and Task Scheduler tasks that were created on my system by this buggy v5.92 release. According to Andavari's 06-Jun-2022 post <here> in bgavin's thread the registry entries were created because the portable.dat file was not located in the same folder as CCleaner.exe and CCleaner64.exe executables in CCleaner Portable v5.92. I now have to manually remove all these unnecessary registry keys and tasks from my system and will be going back to using CCleaner Portable v5.91 for now.
I agree with your comment about Performance Optimizer, Software Updater, etc. I only use the Custom Clean feature and I suspect that most CCleaner Portable users would actually prefer to have many of the "extra" features like Performance Optimizer, etc, removed from the portable build.
64-bit Win 10 Pro v21H2 build 19044.1766 * Firefox v101.0.1 * Microsoft Defender v4.18.2203.5-1.1.19200.6 * Malwarebytes Premium v4.5.10.200-1.0.1702 * CCleaner Free Portable v5.92.9652
Dell Inspiron 15 5584, Intel i5-8265U CPU, 8 GB RAM, 256 GB Toshiba KBG40ZNS256G NVMe SSD, Intel UHD Graphics 620</span>
		To confirm, there will not be a portable version of CCleaner 6.01 either, but we are continuing to review how to portable-ize CCleaner 6.02+. ...
Hi OLLI_S:
CCleaner v6.02 was released today (20-Jul-2022) but the official builds page at https://www.ccleaner.com/ccleaner/builds is still recommending the ccsetup591.zip for CCleaner Portable v5.91.9537 (rel. 16-Mar-2022). ☹️
64-bit Win 10 Pro v21H2 build 19044.1826 * Firefox v102.0.1 * Microsoft Defender v4.18.2205.7-1.1.19400.3 * Malwarebytes Premium v4.5.11.202-1.0.1716 * Macrium Reflect Free v8.0.6867 * CCleaner Free Portable v5.91.9537
Dell Inspiron 15 5584, Intel i5-8265U CPU, 8 GB RAM, 256 GB Toshiba KBG40ZNS256G NVMe SSD, Intel UHD Graphics 620</span></span>
Hello,
CCleaner 6.02.9938 was released yesterday and there is also no portable version available.
This makes me so sad, because I can only use the old version!
OLLI
Please note that the release notes for version 6.02, available here: https://www.ccleaner.com/knowledge/ccleaner-v6-02-9938 includes:
Quote
		<strong>Note about CCleaner Portable</strong>
		We have paused releases of CCleaner Portable while we resolve a compatibility issue. We aim to have this resolved in v6.03.
When I see it properly, then there are also no portable versions of Speccy and Recuva available (at least not the current versions).
Hi OLLI_S:
Please see my 20-Jun-2022 response in CCleaner 6.00/6.01 Portable Not Available to employee Dave CCleaner's comments on this subject. We were told in October 2019 that the portable builds of Speccy, Defraggler and Recuva would be "reestablished shortly" on their respective builds pages (e.g., at https://www.ccleaner.com/speccy/builds for Speccy) but those download links are still missing, in spite of Piriform's insistence that these portable builds "have not died".
The situation with CCleaner Portable is a bit different because Piriform is still posting a ccsetup591.zip file on the CCleaner builds page at https://www.ccleaner.com/ccleaner/builds. The only major issue with CCleaner Portable is that the recommended ccsetup591.zip was released back in March 2022 and will continue to be a few versions behind the "standard" CCleaner installer until Piriform fixes the buggy file structure in CCleaner Portable. That will hopefully occur when the upcoming CCleaner v6.03 is released next month.
Hi OLLI_S:
Just a warning that I launched CCleaner Free Portable v5.91 today (the Portable version currently recommended at https://www.ccleaner.com/ccleaner/builds) and saw a pop-up in my system tray asking me to download the buggy v6.02 files, in spite of the fact that I have all automatic updating and available update checks disabled at Options | Updates. I chose "Remind Me Later" to stay on v5.91.
See my 31-Jul-2022 post in mogil's 5.92 portable broken [download 5.91 from website] for further details.
1912085463_CCleanerv5_91SystemTrayWarningCCleanerOutofDatebyFourVersions31Jul2022.png.22097317ef8f4b55112ea81a32057197.png
64-bit Win 10 Pro v21H2 build 19044.1826 * Firefox v103.0.0 * Microsoft Defender v4.18.2205.7-1.1.19400.3 * Malwarebytes Premium v4.5.12.204-1.0.1725 * Macrium Reflect Free v8.0.6867 * CCleaner Free Portable v5.91.9537
Thank you lmacri for this information!
Hi :)
Any update for CCleaner 6.02 portable ?
Hi Moustik:
Please see employee johnccleaner's 22-Jul-2022 post <above>. CCleaner Portable v5.91 is still the recommended version at https://www.ccleaner.com/ccleaner/builds and Avast/Piriform is hoping (but no promising) to release an updated Portable version when CCleaner v6.03 is eventually released.
64-bit Win 10 Pro v21H2 build 19044.1826 * Firefox v103.0.1 * Microsoft Defender v4.18.2205.7-1.1.19400.3 * Malwarebytes Premium v4.5.12.204-1.0.1725 * Macrium Reflect Free v8.0.6867 * CCleaner Free Portable v5.91.9537
Just an FYI that CCleaner Portable v6.03.10002 (ccsetup603.zip) has been posted on the official builds page at https://www.ccleaner.com/ccleaner/builds and when I unzipped I could see that the executable files are now back in their correct location in the "root" directory with portable.dat. I haven't had time to test thoroughly to see if this version creates any unwanted registry entries or scheduled tasks but so far everything looks okay.
280276564_CCleanerv6_03PortableUnzippedExecutableFilesinCorrectLocation22Aug2022.png.4ad3c6bcc39c78f7b703c3d606491496.png
The release notes for v6.03.10002 at https://www.ccleaner.com/ccleaner/version-history only say "We fixed an issue that would cause a loss of settings in CCleaner Portable".
I have a 64-bit Win 10 OS and use the default English interface and the image below shows the only unzipped files I normally keep . Note that I only use the Custom Clean feature and don't use other features like Health Check, Software Updater, etc. . The only difference I noticed about Custom Clean in v6.03.10002 is that cleaning of my Apple Install files and Firefox Bookmark Backups were enabled by default on my first scan, and I don't want those files cleaned automatically.
1116904411_CCleanerv6_03PortableUnzippedEssentail64-BitFiles22Aug2022.png.1c501be3084afabe687e6584fed1a783.png
522043633_CCleanerv6_03PortableFirstCustomCleanAppleInstallFilesandFirefoxBookmarksAug2022.png.7e353ef004d4d537bbac48c85a6048dd.png
64-bit Win 10 Pro v21H2 build 19044.1889 * Firefox v103.0.2 * Microsoft Defender v4.18.2205.7-1.1.19500.2 * Malwarebytes Premium v4.5.13.208-1.0.1740 * Macrium Reflect Free v8.0.6867 * CCleaner Free Portable v6.03.10002
don't work for me, doesn't launch.
Windows 10 Professionnel 21H2 19044.1889
Windows Feature Experience Pack 120.2212.4180.0
Thank you for releasing the new version!
