don't work for me, doesn't launch. Windows 10 Professionnel 21H2 <strong>19044.1889...</strong>
Hi Moustik:
Do you mean nothings happens when you unzip the ccsetup603.zip downloaded from the official builds page at https://www.ccleaner.com/ccleaner/builds and then double-click on the extracted CCleaner64.exe file (assuming your Win 10 OS is 64-bit), or do you see some sort of error message or warning? Since this is a portable utility I usually copy and paste the extracted CCleaner folders and files over to a removable USB thumb drive in a folder I created myself (e.g., I like keeping all my portable apps in a folder on that USB thumb drive called D:\Portable - I save my extracted CCleaner folders and files in a subfolder I named D:\Portable\CCleaner) but that CCleaner64.exe file should launch correctly from any location as long as portable.dat is in the same folder.
Also note that I keep the same ccleaner.ini file I used with the previous versions of CCleaner Portable (i.e., the .ini file that stores all my custom settings) in D:\Portable\CCleaner and just re-use it so I don't have to reconfigure my custom settings every time a new version of CCleaner Portable is released.
What antivirus do you use? When a new version of CCleaner is released it sometimes takes a few days for the executables to be whitelisted (unblocked) by some antivirus scan engines, but I uploaded the new CCleaner64.exe to VirusTotal.com for analysis today and the report <here> gives that .exe file a detection rating of 0/68, which means that none of the 68 popular antivirus scan engines listed in that VirusTotal report detect the latest CCleaner64.exe as suspicious or malicious.
Before you edited your post <above> you said you were using ccPortable, the PortableApps version of CCleaner. As far as I know that PortableApps version is not endorsed or licensed by Piriform, the developers of the official CCleaner Portable build (ccsetup603.zip) available at https://www.ccleaner.com/ccleaner/builds, so I would suggest you post in the PortableApps forum at https://portableapps.com/forums and ask them if remnants of ccPortable could prevent Piriform's official CCleaner Portable build from launching correctly.
Note that Piriform advised users to continue using CCleaner Portable v5.91.9537 (rel. 16-Mar-2022) until CCleaner Portable v6.03.10002 was released on 22-Aug-2022 (i.e., Piriform pulled the buggy CCleaner Portable v5.92 from their official builds page at https://www.ccleaner.com/ccleaner/builds and did not release CCleaner Portable v6.00, v6.01 or v6.02 on that builds page due to "compatibility issues"). If you installed PortableApps' ccPortable v5.92, v6.00, v6.01 and/or v6.02 I have no idea what problems, if any, this might cause on your system or whether this is why the official CCleaner Portable v6.03.10002 (i.e., unzipped from ccsetup603.zip) won't launch correctly now.
I'm also looking forward to continued portable releases. At least for me, I'm fine if it doesn't have the Performance Optimizer or Driver Updater or Software Updater, as I'm not planning on using these (much too much "feature creep" for my preference).
In the meantime, I noticed that the portable version v5.92 was replaced with v5.91 on the official ccleaner.com download page. What's the story? Was this intentional? Is there a serious problem with v5.92 (besides the following, which has an easy workaround: <a href="<___base_url___>/topic/62829-592-portable-broken/" rel="">https://community.ccleaner.com/topic/62829-592-portable-broken/</a><a href="https://www.kehuafurnace.com/induction-melting-furnace.html" rel="external nofollow">furnace</a> )?
I have already install v5.92 in my company pc. is it good or i have to replaced it too? As if i sign in to ccleaner than i will protected from latest virus.
Hi Steve Kvin:
Did you use the Portable version of CCleaner v5.92 (e.g., the ccsetup592.zip file that you downloaded from https://www.ccleaner.com/ccleaner/builds) that can be unzipped and run from any location, or did you actually install CCleaner v5.92 on your computer using ccsetup592.exe or one of the other self-extracting .exe installers that was listed on that download page? The problems being discussed in this thread only affected the Portable version of CCleaner.
Note that the https://www.ccleaner.com/ccleaner/builds download page is now offering CCleaner v6.03.10002 (released 22-Aug-2022) and it is now safe to update to this latest version, whether you use CCleaner Portable or an installed edition of CCleaner.
You might also want to clarify what you mean by "As if i sign in to ccleaner than i will protected from latest virus". CCleaner is basically a disk cleaner that can clean your browser cookies, temporary Windows files, etc., but CCleaner is not an antivirus and cannot prevent malware from infecting your system, and CCleaner will not automatically detect and remove malware like a true antivirus program. If you require further assistance let us know your computer model, Windows operating system, your antivirus, and which product (CCleaner Free, CCleaner Professional or CCleaner Cloud for Business) you are using.
