DSTM Posted May 27, 2013 Share Posted May 27, 2013 Hi Guys. First post. I find Speccy will not read DDR3 Ram speeds correctly. Any fix forthcoming? Thanks in advance. Link to comment Share on other sites More sharing options...
nodles Posted May 27, 2013 Share Posted May 27, 2013 Speccy version? Could you describe how it's not read correctly (screenshot maybe)? Link to comment Share on other sites More sharing options...
DSTM Posted May 27, 2013 Author Share Posted May 27, 2013 Hi nodles. Will post a screen shot shortly. Thanks for the quick response. Link to comment Share on other sites More sharing options...
DSTM Posted May 27, 2013 Author Share Posted May 27, 2013 Hi Again. I have 4 GIGS of DDR3 1600 fitted. Bios and Boot screen both say 1600 mhz. I am a Techy on a Computer Help Forum and getting the same reported issue from members that Speccy is only reading half of the actual speed of DDR3 Ram. Thanks. EDIT. Also could you tell me why my CPU temp is not showing? Your help much appreciated. Link to comment Share on other sites More sharing options...
nodles Posted May 27, 2013 Share Posted May 27, 2013 Do you mean MHz or MT? Because 1600MT = 800Mhz. Link to comment Share on other sites More sharing options...
DSTM Posted May 27, 2013 Author Share Posted May 27, 2013 That explains it. Learn something every day. I will enlighten the members who are complaining. I recommend Speccy all the time as it helps us diagnose Computer issues.Temp ( Great Program} Finally why doesn't Speccy show my CPU temps? Thanks. Link to comment Share on other sites More sharing options...
