Hey everybody!
Does anybody have a zune 30 with the newest firmware on it?
I have a zune 30 with the new firmware 2.2 loaded on it. In the old firmware, when the zune was fully charged, the battery would turn green. How can I determine if the zune 30 WITH the new firmware 2.2 is fully charged (does it turn green, what does it do?)
Thanks!
usually on most DAPs when it's fully charged it'll display"Charged" or it will do a fade-in/out telling you it's charged. connect the player to one of the back USB ports of your computer and when the "Remove Device Safely" icon comes up click that icon and it'll remove the device and then it should show a charging display. if it's full then it should say "CHARGED" or similar.
Well that's not the case with the zune or the ipod. Does anybody with a zune actualy know?
What?! my step Bro. has a iPod Classic 80GB and when it's fully charged the battery it Green and titles "CHARGED". what is shown while the Zune is charging? a Battery, some kind of Image... what?
