Your Cleaning Suggestions
Hi everyone, you can place all your suggestions for new areas of cleaning here in this thread.
  • It's fine to create a separate thread with details, screenshots, examples and then link it here.
  • Your suggestions can be high-level or very detailed and technical; either is fine.
  • What's really useful is to understand "Why is this cleaning important to you?" This will help us to prioritise our time and efforts.
  • We may follow up with questions, using @mention, which will email the address you used to register to the forums. You can manage your notifications in your forum account.
Going forward, our Cleaning Squad will use this thread as a first port of call for reviewing all the cleaning suggestions together. They will combine that with their other forms of research: reviewing changes in Windows and major browsers, and cleaning gap analysis of other cleaning products.
1) I would like to see a Run command added to CCleaner.
Currently I use a batch program to run CCleaner before my PC shuts down, it calls the script: "tasklist | find /i "msedge.exe" && taskkill /im msedge.exe /f /t"
so that Microsoft Edge (and all child processes are closed) so CCleaner can give Windows 10 a full cleaning.
I think it would be amazing if there was an internal method of: "Run command before CCleaner starts" so I wouldn't have to rely on a batch program to do this.
2) Also, I made another suggestion in one of my previous posts (and the solution) to add a CCleaner icon to the Recycle Bin Context Menu.
Those are my thoughts, thanks!
Thanks for the suggestions Bandit!
Is it accurate to say that the main reasons you want to script actions before running CCleaner are:
  1. to clean more thoroughly (close browsers so they can be cleaned along with everything else)
  2. to clean at a more convenient time (when browsers are not in use)
I would like to see CCleaner use The Same Color Mode as Windows does. A Dark mode if that is what Windows is using.
In Tools show what disc the program is installed on.
Hi, can you add software update for the Corsair iCUE software, i was several versions behind and i would like for this to be included in the driver/software updater if you can.
https://www.corsair.com/us/en/icue
Thank you so much :)
Also the driver updater missed this one
IntelÂŽ 6th-10th Gen Processor Graphics - Windows
Hello, could you provide cleaning for the following Adobe Suite temporary folders?
C:\Users\[username]\AppData\Roaming\Adobe\Common\Media Cache Files
C:\Users\<em>[username]</em>\AppData\Roaming\Adobe\Common\Media Cache
C:\adobeTemp</strong>
Thank you
In English:
In the function "custom clean" I would find profit the possibility to activate or to also disarm in block the various sections they leave you plan the sub-options of each of these.
In Italiano:
Nella funzione "Pulizia personalizzata" troverei utile la possibilitĂ  di attivare o disattivare in blocco le varie sezioni pur lasciano impostate le sotto-opzioni di ognuna di queste.
9 hours ago, paololrp said:
		In English:
		In Italiano:
Right click a heading (such as edge chromium) and choose uncheck all
In English:
Thanks.
However my application was some thinnest!
If I deselect all, loses the state of the planned selections.
If, instead I was able deselect the block, I could leave the active options for a following cleaning.
Otherwise, for re-select as they were previously to the deselecting I am forced to take it notices of it.
In Italiano:
Grazie.
Però la mia richiesta era un po' piÚ sottile!
Se deseleziono tutto, perdo lo stato delle selezioni impostate.
Se, invece, potessi deselezionare il blocco potrei lasciare le opzioni attive per una successiva pulizia.
Altrimenti, per reimpostarle com'erano precedentemente alla deselezione sono costretto a prenderne nota.
Even after uninstalling Adobe Acrobat Reader, on my system there’s few hundred MB or so of leftover install and update files.
In c:\ProgramData\Adobe\ARM
In the form of files like
C:\ProgramData\Adobe\ARM\Acrobat_24.005.20421\AcroRdrDCx64Upd2500120432_incr.msp
C:\ProgramData\Adobe\ARM\Acrobat_24.005.20421\AcroRdrDCx64Upd2500120432_incr.msi
That could be cleaned, both for current Acrobat users and former Acrobat users.
This is important to me because this is pure junk. Caches are easy to clean, but they have actual potential value. Old installer files, not so much.
I suggest that CC Cleaner could find and clean “Crashpad” reports no matter
where they came from, an especially after they are 30 days old. One of many examples would be:
\AppData\Local\Microsoft\EdgeBeta\User Data\Crashpad\reports .
What CCleaner does or doesn’t clear changes with time, but not everyone wants the same things to be cleared - which is why Custom Clean (the original CCleaner) still exists.
You can add your own ‘things to clean’ to custom clean by using Options>Include to specify their pathnames, wildcards can be used.
Remember to also enable ‘Save all settings to INI file’ in Options>Advanced.
For example, these specify that running a Custom Clean removes the CCleaner language and setup files from this laptop (They are not needed once CCleaner is installed, unless you want to switch language, but they get reloaded with every CCleaner update).
I use custom clean (on Nvida driver update files).
But here Edge is far from the only program that uses CrashPad, and leaves big crashpad files.
If CrashPlad cleanup was integrated into CCcleaner, it could delete those from any program, not just the ones where individual customers noticed and created a custom rule.
Example: crashpad files all over. Searching C: for CrashPad gave:
GoogleUpdater
Microsoft Office
Microsoft Windows
Appdata\Local\Dropbox
Zoome
Chrome
Edge
EdgeBeta
Would be awesome if CCleaner had a longer “deep scan” that searched for patterns, such as CrashPad dump junk.
I have two suggestions
General
I would like to see a visible indication of activity while updating software, particularly if using ccleaner to install windows component updates.
MSI Stealth
Among my windows systems, I have an MSI Stealth computer and would like the software updater to update if available, the NVIDIA drivers and the MSI Center,if possible. While I am listing the products, that the updater doesn’t proceess, it also includes Steel Series CG and Overwolf.
Let users have the option to have the CCleaner service start when they start CCleaner rather than have the CCleaner service running constantly in the background consuming resources.
Let users select the first screen after CCleaner opens. For example, I use Custom Clean about 10 times more than any other function in the program. I’d like to NOT have to change that on the left-hand side. I have no idea why Health Check is the first option that appears. I rarely, if ever, use that feature.
I am currently using the free version, but it consumes quite a bit of resources and slows down my laptop. It would be better if it were less taxing on slightly older computers.
CCleaner used to allow the user to clean everything except for running browsers, which it could be told to skip.
Now, all the other cleaning functions of CCleaner are blocked if there’s a browser open.
I’d like to request that the previous behavior, being able to skip cleaning an open browser, but clean everything else, be added back.
