XP home edition
I have XP home edition.Is worth to upgrade ?
What is the difference?
Thx!
Just a quick google search
A few sites worth checking out:
http://www.microsoft.com/windowsxp/home/ho.../choosing2.mspx
http://www.ucs.ed.ac.uk/usd/scisup/faq/homevspro.html
http://www.worldstart.com/tips/tips.php/1433
And in terms of is it worth upgrading you have to look at what you'll be needing it for. But usually the answer is no. Be sure to check the sites above.
I've found Pro handles memory better.
Can you explain?
Yes, please. It's the first time I've heard of this and I'm interested.
I've used identical machines (Minus the OS) where it was Home and Pro. I mean all the hardware, everything was the same. Yet I found that Pro loaded things faster, etc. Could be cause of the extra features too.
By the way!
What it will be the normal time for startup?(approximative)
1 min is too much?
There's a lot of factors in that... Prefetch, RAM, HD, system startup (registry, startup folder) etc.
Professional is also better at networking.
If you have Home but can upgrade to Professional for free then it might be worth it.
If you have Home but consider buying Professional then its definitly not worth it.
how much xp Professional cost?
http://www.google.com/search?hl=en&q=win+x...G=Google+Search
how to get it online
I dont care.
wizKid1,
Please only post when it is relevant to the topic, the discussion was about XP Home or XP Pro. Windows Media Center has not even been questioned.
Whilst I am at it Eldmannen, how can someone upgrade from Home to Pro for free?
We dont discuss illegal software or means of obtaining software illegally here, hence the pinned Freeware Topic.
It's obvious that wizkid is Dhjaahshasjhasaj or whatever.
So is d2e.
So is d2e.
If we don't actively feed the troll by answering his questions or even making remarks it's the first step for him to realize we're ignoring him and he'll eventually go away and bother another forum.
The CCleaner Forums needs a Recycle Bin to move posts to that the admin and moderation consider junk/crap/useless/way off topic.
