Wrong S.M.A.R.T. info if SSD is installed
Hello there! I've noticed an issue with S.M.A.R.T. information in "Health" tab. I have an SSD drive inside my laptop. Also I use an external HDD. When I go to "Health" tab for SSD drive it shows correct information. Then I switch to HDD. "Health" tab shows all info about it correctly except S.M.A.R.T. So device description, firmware and so on - correct, temperature, Power Cycle Count, POH and so on - wrong. S.M.A.R.T. info is taken from SSD. So I can't see S.M.A.R.T. for HDD. I don't remember, but I think the same would be with any other drive.
As I remember, the problem appeared since SSD support was added (Defraggler now can tell whether the drive is HDD or SSD).
I've attached screenshots :)
