Detected on version 1.04 and 1.04. CPU multiplier shows maximum multiplier and not actual multiplier.
Intel Pentium M740 on an Dell Latitude D510.
Please upgrade to 1.05 and report if the issue still exists. If it does it will help the developers if you post your speccy file (via the publish or save snapshot)
http://speccy.piriform.com/results/m3e5wPnf8AB58T3cxcIqKlI
also not sure what you mean by
did you mean 1.05? if so then post the snapshot/speccy
Yes I ment "Detected on version 1.04 and 1.05."
Posted the snapshot on http://speccy.piriform.com/results/dvwtrj6lpnarpEpGB8h5knZ
Found same problem at my desktop. The multiplier and the core speed are not updated. For both cores. They stay as loaded. Posted the snapshot on http://speccy.piriform.com/results/Ka1ftPBzhH5j38hgWI5I8Ox
Ok the developers monitor all threads so they should be able to look into this, thank you.
