what is work resolution for a monitor/graphics card? it allways seems to be a number of pixels lower on the vertical? can someone explain this to me? since there's no documentation on it.
For me, Current and Work Resolution are the same. Try changing your resolutions back and forth and see if it makes a difference.
i have and its normally 40 pixels lower (on my laptop i think it was 30?) changing resolution didn't change the difference in pixels (it was always 40 less)
The work resoluiton is the resoluiton you use (current resoluiton - taskbar = work resolution)... When you choose 'hide' at task bar propriets, the current resolution is the total work resoluiton...
Bye! =D
Bye! =D
thank you ~!
