Won't work
Recuva doesn't work for me. I have only one selection, Hard disk C and when I click scan, it flashes by for a second and then nothing. Can anybody help? Please.
I have exactly the same problem, so add me to the number of dissatisfied users.
Hi, can you both please post error logs so we can look into this further.
Thanks
MrRon
Thanks
MrRon
Same problem, works fine on my other drive and finds ~200 files.
On C: drive when i press scan, the progress bar flashes on and off and there are no files displayed. :blink:
There must be some files as this is my main drive and so files are regularly deleted.
There are no error logs generated in the Recuva folder.
Hope this helps
Post the error logs first then, try running a check disk scan of your c: drive
Start, Run, type chkdsk C: /F
Note: This will require a restart to run the check.
Take note of any disk errors that are reported and post them here for MrRon as well.
What is up????
Error Log from debug: (program flashes and goes nowhere)
Recuva v48
System Info: MS Windows XP SP2, Intel Pentium 4 CPU 3.00GHz, 2.0GB RAM, NVIDIA GeForce 6800 GT E8
[0:23:37] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:23:39] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:6] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:8] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:9] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:10] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:11] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:12] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:13] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:14] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:28] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:29] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:30] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:31] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:32] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:33] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:26:34] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:28:3]
=== Debug Mode====
[0:28:7] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:28:10] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
[0:28:11] ErrorNo: 3 OtherInfo:cundelete_recdrv2 Error No:536870916 ErrorInfo:Failed to read boot sector.
That's really useful, we're looking into this and hope to have a fix soon.
MrRon
