Wndows explorer options
I have win xp os and installed cc. Whenever I open the windows explorer (after fresh start of laptop) the file listing is in Tiles Mode where as I would like it to be in Details Mode. I change the same manually every time I restart.
This was not the case before installation of CC. The Windows explorer would open in the mode I had last saved in.
How can I keep the same mode for Windows explorer with cc installed ?
Would appreciate if somebody could suggest how to do the same.
Thanks
Do you have Window Size/Location Cache ticked under the advanced section?
